prius vs airplane
Discussion in 'Fred's House of Pancakes' started by Former Member 68813, Feb 12, 2015.
  1. Former Member 68813
    3,524
    983
    US
    this is about MPG and not crashes, BTW.
    based on this: Ranking the Airlines by Fuel Efficiency - WSJ
    this is my compilation:
    Prius (5 passengers): 250 mpg per passenger
    737-900: 99
    787-8: 98
    767-400ER: 96.9
    777-200ER: 82
    A320: 77
    A380: 65
    Prius (1 person): 50
    the surprises: Airbus planes are way behind. The smaller planes have better fuel efficiency per passenger. 737 is more fuel efficient than the 787 Dreamliner, probably due to the difference in the length of the trips (longer = worse fuel economy).
    edit: included the 787 numbers from:
    Green Car Congress: Boeing Rolls Out the 787 Dreamliner; New Jet Offers 20% Reduction in Fuel Consumption
    #1 Former Member 68813, Feb 12, 2015
  2. Mendel Leisk
    40,574
    Hmm, remember coming back to Canada in a 747, non-stop from Amsterdam. They were showing The Sting.
  3. bwilson4web
    16,010
    So when I flew to Texas to pickup our used, 2003 Prius:
    I asked the flight crew for how many passengers on each leg and fuel burned.
    #3 bwilson4web, Feb 13, 2015
  4. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    There's a very good comparison chart - which even brings the Prius into play - at Fuel economy in aircraft - Wikipedia, the free encyclopedia.
    There's no significant difference between comparable Airbuses and Boeings. What is remarkable, though, is how much more economical the new composite planes - the 787 and A350 are - than the old pig-iron-and-brick ones (the revamped models - the 747-8 and the A330neo - fall between the two groups), and how similar the figures for all the pig-iron-and-brick planes are, regardless of size. Bigger planes are a bit more economical than smaller ones as a rule, but the variation isn't as big as I'd have expected.
  5. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Last time I checked the 747 was the main jet.
    It was 50 miles per passenger.
    Efficiency has improved in the past 15 years.
  6. Former Member 68813
    3,524
    983
    US
    you are right, that source is much better. but, boeing still leads in every category and bigger is not better though (that's the biggest surprise for me).
    see this from the source i quoted:
    #6 Former Member 68813, Feb 13, 2015
    bwilson4web likes this.
  7. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Bob; you are my hero :ROFLMAO:
  8. GregP507
    GregP507 Senior Member
    3,002
    481
    Airplanes have an intrinsic form of regeneration. The power you apply, is translated into speed and/or altitude. These two factors are inter-convertible to a large degree; you can trade speed for altitude and visa-versa, within the limitations of altitude and air-resistance.
    An interesting thought: perhaps a hybrid airplane could recharge it's battery upon it's descent from higher altitudes.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    hybrid airplane with current level of battery density??
  10. GregP507
    3,002
    481
  11. cyclopathic
    3,292
    547
    2014 Prius c
    There is no real info in your link.. just typical PR BS
    But even if they had real break through and double capacity, by weight the energy density of Lithium-Ion batteries is 50-120 times lower than regular gas (52.5-130 times of jet fuel):
    Energy density - Wikipedia, the free encyclopedia
    So at present level of technology it is a beautiful pipedream.
  12. GregP507
    3,002
    481
    No, I'm not making any unsupported claims, so take a rest.
    If a hybrid airplane should some day exist, it would naturally be able to regenerate from the descent, instead of bleeding off all the airspeed with landing-gear and flaps. My posting about battery developments was merely to remind everyone that battery technologies continue to evolve, therefore you can't rule out a hybrid airplane some day.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    didn't mean to take you on guilt trip; just being skeptical..
    would be nice if we get there
  14. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    At EAA Oshkosh 2013 a new propeller with a wider, slightly shorter blade was shown by Pipistrell (IIRC!) that enabled regeneration on descent for their battery powered sailplane model. That was research result so not sure if it is in production yet although I believe they had taken out a patent on it.
  15. GregP507
    3,002
    481
    Variable-pitch propellers have been around since the 1930s or before. It may not be outside the realm of possibility for variable-geometry propellers to some day become a reality. Just trying to think outside the box.
  16. Onager
    Onager Junior Member
    Anybody have data like this for cruise ships?
