Prius White 2002 Red Triangle
Discussion in 'Generation 1 Prius Discussion' started by JoelMcClark, Apr 10, 2022.
  1. JoelMcClark
    JoelMcClark New Member
    ChesterTown MD
    2002 Prius
    The Prius Sat For About A Month. Came Back To IT About A Week Ago. The Car Had No Warning Lights For About 20 Miles After Sitting For A Month. Then The Warning Lights Came On. I Had It Since About New. Bought In 2004. The Car Loses Power. Can Anyone Tell Me If This Will Be A. Expensive Fix And What Needs To Be Done Get The Red Triangle Gone? I’m In ChesterTown MD. Thanks Joel.
  2. Tombukt2
    Tombukt2 Senior Member
    8,947
    1,558
    Durham NC
    Shoot over to hybrid doctor in VA . AB will fix you up nicely Ive his number . Ring me up if ya like I gotta folks in Bethesda 9198920363
  3. JoelMcClark
    ChesterTown MD
    2002 Prius
    Do you know what the codes mean before I call him?
  4. ChapmanF
    15,509
    The four codes your scan tool didn't know the meaning of are:
    P3006 - the charge state is uneven across the battery modules (this you knew already from the first two codes the tool recognized)
    P3029 - internal resistance of block 19 is abnormal
    P3130 - some malfunction in the pump/cooling system for the inverter/converter electronics
    P3125 - some problem with the inverter/converter electronics
    P3125 is a very general code, with something like 81 possible subcodes that a suitable scan tool can read. Without the subcodes, it is pretty vague. But given the P3130, it is possible the problem was secondary to bad cooling and will be resolved by fixing that.
    The P3130 does have two different subcodes, which will tell you whether the ECU thinks it's more like the cooling problem has to do with the pump or with the radiator fans.
    WHCSC likes this.
  5. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    Expensive, time for a new HV battery, but if all else is working, worth it. New Toyota battery is best, and they've really come down in price. Aftermarket rebuilt batters are a bit cheaper, but my experience is they're only as good as their warranty, one or two years.
  6. JoelMcClark
    ChesterTown MD
    2002 Prius
    Is the car worth the money for a cooling pump and hybrid battery?
  7. JoelMcClark
    ChesterTown MD
    2002 Prius
    So the subs codes were P3130 346 P3125 322 P3029 P3014 P3006 P3015 didn’t have any sub codes I had my mechanic look at it since he had a Techstream. He also found a P3009 code which says The Leak Detected which I think is in the hv battery as well
    #7 JoelMcClark, Apr 11, 2022
  8. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    For me the answer is yes. My '01 has relatively low 145k miles, and with the new Toyota HV battery and regular maintenance, I expect to get another six to ten years out of it. It'll be a real antique by then. :)
  9. Tombukt2
    8,947
    1,558
    Durham NC
    That's an 8 K car et now 145K on a prius looking good . Dummies are paying that for gen2 w 190K ready for ABS failures they may not be able to buy out of!
    ammdb likes this.
  10. ChapmanF
    15,509
    P3130 346 is specific to the inverter cooling water pump or wiring that serves it.
    P3125 322 reflects overheating of the inverter section for MG1.
    #10 ChapmanF, Apr 13, 2022
    WHCSC likes this.
  11. JoelMcClark
    ChesterTown MD
    2002 Prius
    I wonder if that is bc of the inverter water pump is bad any ideas where I can get it fixed at?
  12. Tombukt2
    8,947
    1,558
    Durham NC
    If you don't hear that little pump running and see water moving in the pink colored reservoir next to the silver covered inverter on the right hand side of your engine compartment if you undo that cap and water's not moving a little bit you should see it you should order a water pump online an attempt to put it on with a long set of needle nose pliers a quarter drive 10 mm socket a long extension and thinking about it for a minute and there's tons of videos it's a very easy repair even for a desk jockey really simple the minute you put in that new pump and fill up that reservoir and push the button on the car that pump's going to start to run suck the reservoir down a little at which point you'll add it up to the full line or close to it and that'll be the end of that until it goes bad again make sure the fuses that correspond to that are up to snuff
  13. ChapmanF
    15,509
    Yes, a causal relationship between the P3130 346 and the P3125 322 is not a big stretch. :)
    If you're at all handy, I would suggest picking up the pump at the dealer and a jug of SLLC and changing it yourself; it's a pretty straightforward job. (That might be what Tombukt2 was saying, too; I can't quite tell.)
  14. JoelMcClark
    ChesterTown MD
    2002 Prius
    Ok my hybrid battery is fixed by green bean yesterday I upgraded to 50$ For life time warranty. It only cost
    $1974$ For that battery. My battery is going to all the way to top which is great is it working great so far. My mechanic fixed my pump which resolved the code for the inverter and the pump the car is working great and Saturday he fixed the pump. I ordered the part and they had so I picked it up for around $100 and had him install for 400$ so I saved a lot of money.
    Josey and ammdb like this.
