Prius will start but only runs a few seconds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ruggb, Jan 12, 2013.
  1. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    HELP!
    My 2004 Prius is due in the shop Tues for a hybrid battery replacement. Codes indicate only one cell bad BUT...It is obviously having some problem running. We were very low on gas yesturday but wife filled it before she came home. She parked it in garage. The Hy Batt indicated all green bars.
    She may not have pressed the Park button before Power - I do that a lot too.
    This AM I changed the spark plugs before I tried to start it. I then started it (ICE & started-sounded OK) and backed it DOWN the driveway into the street and started down the street. The ICE stopped.
    The batt indicated one blue bar so the batt would not propel it. After trying a couple times to make it run, I disconnected the 12v grd and let it sit for an hour. Then I reconnected the batt and the ICE again started showing hybrid at 4 blue bars and stopped after a few seconds. Tried it once or twice more, same thing.
    What to do????? Hate to have to tow it Tues.
  2. Patrick Wong
    18,210
    6,513
    Well, if the car refuses to run then you have no choice other than to have the car towed.
    I'm not sure why you replaced the spark plugs, but if you have any concern about whether you did that properly, you might recheck your work.
    How long did the engine run when you first started the car? If it only ran for a very brief period, then it is possible that the engine did not actually start and that MG1 was just spinning it, in an effort to get the engine to start. Once the engine starts, rev it up using the accelerator pedal to prove that the engine is actually operating.
    There is no problem if you do not select P prior to turning the Prius off. The transmission control ECU will automatically select P prior to powering down.
  3. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    Well, I posted everything just in case.
    Turns out the correct answer is -- I screwed up --
    When I replaced the spark plug coil assy the right most unit connector is covered by a plastic assy - looks like a wire trough.
    That is the ONE connector that must be removed. Somehow I felt that I didn't get it back on but when I looked it appeared like it was --- NOT.
    what I was seeing was the body of the coil assy. So that piece of info was relevant after all.
    Most 4cyl ICE would run after a fashion on only 3cyl. The Prius, however, is too smart for my own good. It know one is not connected. -- SO why does it even run the MG1 if it is so smart???
    thx - I have another ?? new post
