Prius Windows going crazy on me
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zfk110, Mar 16, 2022.
  1. zfk110
    zfk110 Junior Member
    97
    Atlanta, Georgia
    I got 2010 Prius, my windows are going crazy on me, see these videos for back and front windows.
    I didn't upload 3rd back passenger window's video, which won't work from master control, only works from the same control in the door. So all together 3 windows not working properly. IDK if it's control switch related or something else?
  2. Tombukt2
    Tombukt2 Senior Member
    13,400
    2,413
    Durham NC
    are you pushing button at all in this videos? is the master button assy in door damaged do buttons feel as always . think about this now . are buttons sloppy or depressed without touching control?
    zfk110 likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Check the 12v battery voltage
    zfk110 likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,050
    5,303
    Pacific Northwest, USA
    That's the sensor that's designed to protect kids and adults from getting their arm stuck in a closing window... Simply clean and inspect the rubber channels the window slides in to find out where its getting jammed up. I've found silicone lubricant spray is a good way to stop this from happening.
    Anna-li and zfk110 like this.
  5. ChapmanF
    18,536
    When the window goes all the way up and then dances back, the way your rear-window video shows, that usually means the regulator has forgotten where 'up' is.
    It is programmed to dance back any time it hits something that stops it. It has to learn the one allowed exception ("if you are all the way up, then what stopped you was the top of the door, and that's ok"). See the repair manual (more info) for how to teach it.
  6. zfk110
    97
    Atlanta, Georgia
    Yes, when the glass is down, I was pushing it up. Master button seems to working fine, it happens even if I use their main controller from the same window.
  7. zfk110
    97
    Atlanta, Georgia
    I just put brand-new battery there is no other issues with the car, e.g. starting or anything else. It shows 12.8
  8. zfk110
    97
    Atlanta, Georgia
    I was thinking the same, let me put some lubricant to see if it can help or not.
  9. Tombukt2
    13,400
    2,413
    Durham NC
    Yes-like camper said maybe there’s a stick point in the guides it hits it thinks it’s sposed to back off . And does and repeats . That or very worn contacts in master switch
    zfk110 likes this.
  10. zfk110
    97
    Atlanta, Georgia
    I fixed two windows with lubricant, now I can't get the 3rd one fixed I got the main switch and window switch replaced but still nothing, that window will work fine with its windows switch but from master switch it would only go down, not up.
  11. ChapmanF
    18,536
    Any blinking of the switch LED for that window? More info in this post.
