Prius Windows Specs
Discussion in 'Knowledge Base Articles Discussion' started by Tideland Prius, Sep 4, 2007.
  1. Tideland Prius
    16,155
    ...........................................................................Visible Light Through Rate...UV Cut Rate
    Window Sealed Glass.......Green IR Cut Glass...............................77%.............100%
    Front Door Glass.............Green Water Repelling UV Cut Glass.......72%...............91%
    Rear Door Glass..............Cool Green UV Cut Glass.......................57%...............89%
    Front Quarter Glass.........Green UV Cut Glass...............................72%...............91%
    Rear Quarter Glass..........Cool Green UV Cut Glass......................53%................90%
    Back Door Glass Upper....Cool Green UV Cut Glass......................53%................90%
    Back Door Glass Lower....Dark Gray............................................27%..................93%
    Hopefully the alignment shows up properly on your screen.
