Prius with 193K miles and repeatedly dying 12V: repair or donate?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KEF, Jul 14, 2015.
  1. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Trying to figure out whether to fix or scrap our 2005 Prius with 193,000 miles and a mysterious 12V battery problem. What would you do in my situation?
    We've had a recurring problem with the 12V accessory battery: I have replaced it myself three times. The last failure was the most mysterious, because after replacing the 12V battery for the third time, I conducted nearly daily voltage tests using the Prius' "secret" vehicle signal check. Voltage coming off of the 12V was normal, if not high the entire time in all of the Prius's various starting and ready modes. I wired up a solar panel to trickle-charge the 12V battery when we weren't around, and we plugged the 12V in at night to a trickle charger to keep the battery topped up.
    Nonetheless the day came a few months after the latest replacement when we had our usual 12V failure symptoms: the time on the clock started resetting, the car didn't turn on on the first press, the Prius computer rebooted, and eventually the car wouldn't start without a jump start. This has been super-frustrating, and googling around, I haven't been impressed by people's reported experiences trying to have the dealer try to resolve such problems. My worry is that a dealer repair person will change the accessory 12V battery without fixing the underlying problem. I would suspect a parasitic draw somewhere, but voltage tests when the car was overnighted without any kind of charging did not suggest a serious voltage draw on the 12V battery.
    Other details about the car: our keyless entry hasn't worked for several years (dead batteries in the key fob?) and we open the car manually using the key each time. We stick the fob in the slot each time we want to start it. MPG is comparatively low vs. other Priuses, perhaps 44-45 MPG, and lower when the 12V battery starts to die (37-40). I have had the car serviced (oil, etc.) like clockwork every three months; recently, I've noticed the engine is starting to burn oil a bit (level is reported low on each change).
    Most of the driving has been done in the flats and the heat of California's Central Valley, and we've put something like 120,000 miles on it just in the last five years. Besides the fact that the 12V battery keeps dying, the car has been very reliable.
    We just inherited a free Prius with just 60,000 miles on it, and I have a 1993 Camry with 150k miles on the chassis and maybe 60k miles on the replacement engine I had dropped into it a few years ago. The Camry just passed California's smog test and seems to be running well. We don't want or need three cars.
    Our choice is to try to fix the Prius with 193k miles on it and donate the Camry (which gets about 20 miles to the gallon, the horror...), or keep the Camry and donate the Prius. My instinct is to not drop thousands of dollars into the high-mileage Prius, especially if these issues might be pointing to a dying main battery.
    I'm in the Sacramento area and we are proximate to San Francisco and the Bay Area if that helps the repair picture.
    #1 KEF, Jul 14, 2015
  2. JC91006
    16,748
    8,553
    ok, if you must donate....I'll be the guinea pig and take it. :D
    How many days do you get before the 12v goes dead? You need to check the voltage when the car is running, the car might not be charging the 12v.
    Do you have any sticking buttons on your fobs? Check both fobs and see if any of the 3 buttons don't click when you press them
  3. valde3
    valde3 Senior Member
    2,002
    748
    Finland
    What is the charging voltage from secret menu (voltage when Prius is in ready)? Have you actually measured any voltages with multimeter? Is the ground cable tight where it attaches to body?
    Fob problem just sound like fob battery.
    None of the things mentioned sound anything like failing HV-battery (main battery). Actual parts to repair the problem are cheap or even free. Basically Prius just has a few expensive and commonly failing parts other parts are cheap used. Or the repair might not even require you to buy any parts.
  4. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    contact Luscious Garage | Hybrid Specialists
    • 475 9th Street
    • San Francisco, CA 94103
    everyone says they are the best at the prius gremlins
  5. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Thanks. The 12V lasts for months in some cases before dying. This has led me to speculate that what might be happening is that we are occasionally inadvertently doing something that may be killing the 12V battery in one fell swoop. These seems particularly likely given my repeated voltage tests that indicated normal volage. The replacement 12V batteries we've been buying are said to be the best (Optima and Exide.)
    The fobs don't work, to my knowledge. My wife tried to replace the batteries but keyless does not function AFAIK. She lost one of the fobs awhile back -- she left it on top of her car -- and one of my crazier 12V theories was that perhaps it fell into the engine compartment or other place in the car and was permanently waking the keyless entry, leading to premature 12V battery death. But she lost it more than a year ago, and I am skeptical this is what is going on. As I mentioned in my original message, we enter the car using the manual key and insert the fob into the slot before powering the car on.
    I attempted to use a multimeter to do a parasitic draw test on the 12V battery, but I found it is very difficult to do this in a prius for a few reasons. I didn't track anything down. I don't pretend my analysis was particularly good or complete.
    Car will go to charity if we decide to give it away, alas. :)
    Yes, this has been driving me crazy, and it seems so sad to scrap a car that we've maintained well, and still seems like it has a lot of life in it. My instinct has been that this is something I should be able to fix. But I haven't tracked down the problem.
    Answering your questions, I repeatedly followed the 12V battery check procedures on the tutorial at PriusDIY. After putting in a new battery the voltages were on the highest end of what was recommended. In "ready mode" (test #3 as described at the PriusDIY tutorial) the charging voltage was repeatedly, if I recall correctly ~14.1 or 14.2, which is in the "normal" range as described by the PriusDIY tutorial.
    You asked about the ground cable. You're talking about the cable that leads off the neg terminal of the 12V battery and presumably screws somewhere into the frame? Maybe I should look at that, especially since I've been the unschooled guy replacing the 12V battery repeatedly. If it's not tight, that will kill the battery? Should I clean both ends of it? Is there a way to test if the 12V battery is getting the juice it requires to recharge? Should I be giving up and bringing this into a real Prius repair-person?
    #5 KEF, Jul 14, 2015
  6. JC91006
    16,748
    8,553
    I think you may be onto something about your wife losing the key fob and it is constantly communicating with the car.
    You can try to turn the SKS off, see if that'll fix your problem. There's a SKS button right by your knee, under the steering wheel. Turn that off and see if your 12v drain disappears.
  7. KEF
    KEF Junior Member
    38
    Sacramento, CA
    I tried that after the last battery died, though I am very tall and it is possible my knee has inadvertently toggled the SKS button in the interim. Do any of you know offhand which position disables the SKS system (push it IN to turn it off, or push it OUT to turn off SKS?) I can check to see if it was set to the wrong position.
    It would be nice if there was a way to pull fuses to disable the cabin lights, trunk open lights, SKS system, and anything else that isn't essential to safely run the car -- we could eliminate a lot of possibilities.
  8. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    What kind of 12V batteries have you been using?
  9. JC91006
    16,748
    8,553
    pushed in = off
  10. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Thanks. First I bought an Optima 8171-767-FFP (DS46B24R) YellowTop Prius Battery and then for the next two switch-outs I bought two of the Exide Edge FP-AGM51JIS Flat Plate AGM Sealed Automotive Battery. In an attempt to keep the battery charged, I bought a NOCO Genius G3500 6V/12V 3.5A UltraSafe Smart Battery Charger and used the AGM setting. Voltages were reading normal, and then one day the Prius clock started resetting, the computer started rebooting, and eventually the car would only start intermittently.
  11. bisco
    51,654
    when a 12v 'goes bad', have you tried charging it?
  12. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Verdict: keyless entry system was disabled. I don't think this was the culprit.
  13. JC91006
    16,748
    8,553
    The good thing about a 12v going bad prematurely, it's usually warrantied. You can try getting a Toyota OEM battery and try that.
  14. KEF
    KEF Junior Member
    38
    Sacramento, CA
    hmmmmmmmmm. you may be getting at something, here. I permanently attached terminal "loops" to the 12V battery so that I could easily hook up the NOCO Genius G3500 6V/12V 3.5A UltraSafe Smart Battery Charger and the NOCO Battery Life BLSOLAR5 5 Watt Solar Battery Charger and Maintainer in an effort to keep the battery alive. There is a quick-connect system along with a NOCO Genius GC004 10' Extension Cable (check links on amazon if this isn't clear; I can't yet embed links in messages myself.)
    Well, the last few times I've attempted to plug in the charger to trickle-charge the 12V battery via the system I'm describing above (after the 12V battery "died"), the charging has either not started, or it reports 25% and then stops. I thought maybe something had gone wrong with my charger, or the 12V battery was dead. But maybe the issue is with the connections to the battery, or with the "ground cable" that was mentioned earlier in the thread.
    Note I did not have this charging/ quick connect system for the first two 12V batteries I replaced, and those batteries failed as well.
    The last time I replaced the 12V battery was in late April of this year. It shouldn't have failed so quickly. The replacement I put in place was a Exide Edge FP-AGM51JIS Flat Plate AGM Sealed Automotive Battery
  15. Beachbummm
    1,160
    392
  16. bisco
    51,654
    that's definitely an elaborate system you want to eliminate as a possible problem. i would disconnect everything from the battery, reconnect the terminals and ground point at the body. then i would start using the under hood jump point for battery testing and charging.
    after the car has been off for a few hours, check the voltage at the jump point with a digital multimeter. you'd like to see 12.7 or better on a fairly new battery. 12.4 might be acceptably low, and below that, you'll be running into problems.
  17. KEF
    KEF Junior Member
    38
    Sacramento, CA
    I'll try that, thank you. If all else fails: can somebody suggest a 12V battery disconnect switch that works well with the ergonomics and placement of the Prius' 12V battery? Ideally there would be some kind of a switch attached to a lead wire, such that I won't have to disassemble the entire rear compartment of my Prius every single time I want to disconnect the 12V battery.
    I like the Prius, but boy, the inaccessible, underpowered 12V accessory battery is just about the stupidest car design decision I've ever seen. I can't fathom why Toyota designed the Prius this way, except to make maintenance shops perennially happy.
  18. JC91006
    16,748
    8,553
    You need the 12v to be working to open the hatch. A disconnect switch would be very problematic.
    I suggest you go with a new Toyota OEM battery with a 84 month warranty. Make sure it's fully charged before you connect it to your car = 13.0 volts. Also clean the battery terminals and ground cable. Make sure you have a good clean connection. Disconnect whatever gismo you have on it now, and try again.
    This will cost about $200 to try.
  19. KEF
    KEF Junior Member
    38
    Sacramento, CA
    thanks. and if I want to test most effectively for possible parasitic draw, what's the best and easiest way to do that? Should I shut myself inside the Prius, wait five minutes for everything electronic to quiet down, and crawl to the back of the car where I've pre-disassembled the space so that I can get at the 12V battery terminals? or can I do those checks from the under-hood terminal? I have an auto-ranging multimeter, and a clamp-on multimeter.
    Is there an authoritative way to test for the amount of current that's actually going into the 12V battery via the Prius' version of an alternator? My prius reports normal levels, but ideally you could test this at the battery connection itself.
    I'm wondering how easy or how hard it is for an authorized Toyota shop to do these diagnostics. The harder they are to test, the less confidence I have that the workers will actually do the necessary work. I don't want someone to just guess at the problem: I can do that a lot cheaper myself. :)
  20. JC91006
    16,748
    8,553
    You can buy a cheap $10 multimeter and check the voltage yourself....right under the hood, there's a jump point there (similar to going back to the battery terminals itself..
