Prius won’t start, and has red car with key light on
Discussion in 'Gen 2 Prius Main Forum' started by Diana Alvarez, Oct 13, 2021.
  1. Diana Alvarez
    Diana Alvarez New Member
    Stockton, CA
    after replacing the water pump my car 2009 Prius doesn’t want to start. I noticed a blinking red car light with a key on the dash while I have my key inside with me. I know this means that the security is active but why can’t I turn on my own car? I have 2 keys and tried both but neither of them work. Lights turn on and car unlocks and locks. When I try to turn it on it does nothing.
  2. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    Hi and welcome to Prius Chat.
    Which (of the 4 on the Gen 2) water pumps did you replace? If it was the inverter coolant water pump, did you check the AM2 fuse as well?
    BTW, your posts are moderated (which means your posts are not visible until they are approved my a moderator) until you have 5 or more posts.
    Diana Alvarez likes this.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    How old are the batteries in the key fobs? Did you try putting the fob in the slot in the dashboard?
    Raytheeagle likes this.
