Prius won’t start
Discussion in 'Prius c Main Forum' started by AZ Girl, May 9, 2023.
  1. AZ Girl
    AZ Girl New Member
    AZ
    2014 Prius c
    I replaced my Prius c 12v battery and now my car won’t start in the morning unless I lock and unload my back doors. Help …
  2. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    Recheck the battery connections.
    Remember, when you put the terminal clamp over the battery post, tap it downward gently with the back of a screwdriver or something. THEN tighten the clamp.
    Otherwise you get an iffy connection.
    52,406
    any lights at all on the dash?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Including the OTHER ends of the main cables.
    Slamming a door might accomplish the same thing.......IF the frame connection of the negative cable is loose.
  5. AZ Girl
    AZ Girl New Member
    AZ
    2014 Prius c
    I had them check my battery when I replaced my spark plugs and then a few days after it happened again. No power so I open the back right passenger door and the power comes on. No lights on the dash or anything until I open the door. My check hybrid system came on again as well. No other issues going on with the car. I just don’t want to have to pay almost $200 bucks just to get it checked by the dealer
  6. bisco
    52,406
    sounds like a lose connexion
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Well pretty much nobody WANTS to do that.......but what are your alternatives ?
    Do you have a voltmeter.......and know how to use one ??
    So far, it doesn't appear that you are hearing the suggestions being made.
