Prius won't start correctly. just had the 12v changed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hach, Jan 17, 2018.
  1. Hach
    Hach Junior Member
    23
    indianapolis, in
    So my battery died over the weekend, got it towed to Toyota and they replaced the 12v battery. I went out to start the car today and the lights come on like it normally would but the engine doesn't kick on. When I shut it off the P D R N don't shut off and just keep blinking. No triangle of death or anything.... any ideas? I can't really afford another tow..
    51,155
    you need to check the 12v health, and also the connections. it is possible you have a bad MID.
  3. Hach
    Hach Junior Member
    23
    indianapolis, in
    MID? Even if it's new it could be bad?
  4. Prodigyplace
    12,407
    11,682
    Central Virginia
    I think he is referring to the combo meter that has the speedometer and the warning lights. If it goes bad, there can be unusual symptoms.
  5. Hach
    Hach Junior Member
    23
    indianapolis, in
    I had that replaced last year under the recall, could it have gone bad again?
  6. Prodigyplace
    12,407
    11,682
    Central Virginia
    I would not think so. Perhaps the new 12 volt battery was not fully charged.
    When you turn on the car, is the READY light lit?
  7. Hach
    Hach Junior Member
    23
    indianapolis, in
    I don't think it does as the brake won't got to the floor to shift and no engine kicks on. When I try and turn it off the park, drive etc lights stay on and keep flashing and the center console stays on too.
  8. Prodigyplace
    12,407
    11,682
    Central Virginia
    You may want to disconnect the 12v battery to see if you can get it to shut off before it drains the battery.
  9. Hach
    Hach Junior Member
    23
    indianapolis, in
    I went back out and finally got it to go off. I put the key in instead of leaving it out and it turned off. Still won't start right but least the battery not drainimg
    Prodigyplace likes this.
  10. Prodigyplace
    12,407
    11,682
    Central Virginia
    Is the key fob battery weak?
  11. Hach
    Hach Junior Member
    23
    indianapolis, in
    It still opens the doors and everything fine and if it was bad it should still start when the keys inserted right?
  12. Mendel Leisk
    40,586
    Have you got a multimeter? Check the voltage, at the under-hood jump start point is fine. A brand new battery, it should be reading at least 12.6.
    It does kinda sound like some sort of parasitic drain, to chime in.
  13. Hach
    Hach Junior Member
    23
    indianapolis, in
    Got it to Prius today. They said it was most likely caused by ice build up on the brake relay switch. They couldn't find any other issue so hopefully that's it.
  14. bisco
    51,155
    i hope so!
