Prius won't start humming whirling sound and rotten egg smell
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by T. Hung, Aug 17, 2013.
  1. T. Hung
    T. Hung New Member
    Hi guys,
    I just want to share my troubling experience which may be helpful.
    One morning, I went to my garage and tried to start up the car and it won't start.
    Before I got into the car, I've noticed a humming and whirling sound that is louder than the usual humming. The car was also emitting a weird rotten egg smell.
    The panel lights came on, but seemed more dimmed than usual. I pressed the start button several times, but all it does is turn the instrument lights on and off.
    I did a bit of research, and it ends up that I only needed to swap out the 12-volt auxiliary battery.
    The battery is located at the rear passenger side.
    Since my hatch door won't open without enough auxiliary power, I had to gain access to it by removing the cover to the spare tire. Once I expose the internal latch of the hatch door, I was able to lift a lever by the latch (just like the one for the hood) and push out and up to open the hatch door internally.
    The 12-volt battery is fairly easy to remove.
    I did not order an oem battery through the dealer; instead, I bought an Optima yellow top from Autozone (I don't work for Autozone nor Optima).
    I think they last longer than oem, and they are immuned to drains.
    It has been two weeks now and my prius is running like new.
    Andrewf and Eclipse1701d like this.
  2. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Did the original battery have any obvious corrosion?
    Was the battery vent tube attached before you removed the original battery?
    Was the "rotten egg" smell (typically hydrogen sulfide gas) coming from the original battery?
    I know, so many questions... :rolleyes:
    49,446
    nice write up, thank you T!(y)
  4. Former Member 68813
    3,524
    981
    US
    I guess one should make a sticky post and list all the 1,000 symptoms bad 12V battery can produce.
    Noise and rotten smell is not the thing that comes first in the mind.
  5. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    what was the mileage of the car when it died?
  6. T. Hung
    T. Hung New Member
    Yes the vent tube was attached.
    Yes, the smell came from the original battery which showed no sign of corrosion.
    The issue occurred around 49,000 miles.
    Also like to mention that about six to seven months ago we accidentally left the car on over night and found the car completely dead with no power the next day. We got a jump from AAA then it was running fine until recently. So, if a battery had been drained completely then the chances of it becoming cooked like mine is likely to occur.
    spiderman likes this.
  7. RRxing
    2,520
    1,791
    NEPA
    Thanks for the update. A little detail like a completely drained battery might have helped us out if we had known earlier.
  8. suirpcd
    suirpcd Junior Member
    va
    Did you try to jump start it and it still failed?
    I had these problems (whirling noise near fuse box and, no acc lights, and rotten egg smell) last night, and jump starting it didn't work either, and it was towed to the dealer.
  9. suirpcd
    va
    Just wanted to update my last post to confirm that it was also the 12v battery that died on me. Dealer said it had a bad cell and was causing rotten egg smell (sulfuric acid). I asked if they would prorate the battery warranty but they said it was only for 36 months, and only the replacement battery has the 84 month warranty.
    I never had a battery that failed before 4 yrs on a new car and it refused to jump start.
  10. Andrewf
    Andrewf New Member
    Houston
    2014 Prius c
    I had to create an account just so I could say thank you. This post saved me so much stress and headache. I appreciate you.
