Prius won't start in the cold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ninaherrera, Jan 29, 2021.
  1. ninaherrera
    ninaherrera New Member
    california
    Hi all,
    I've had my prius for about 2 years, each year as soon as it is getting cold my prius refuses to turn on. I press the start button and all the lights turn on. Last year it would take 2-3 attempts to turn on it is now take 10-12 tries. What I've done: I've done a 12volt battery check (it's all good), I've checked all the battery cells (all good), I've done a tune up, I've replaced the ecm.
    Any suggestions?
  2. JC91006
    16,482
    8,397
    how did you check the 12v battery?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Exactly what did you do to check it ?
    The odds are overwhelming that it is NOT good.......either the battery itself or a corroded connection.
    You have already spent a fair amount of time and money on a wild guess, while overlooking the obvious.
    The battery might be WAY over 2 years old and that should have been the first thing you did.
  4. ninaherrera
    california
    I took it to autozone and they did a battery check and they said it was good.
  5. JC91006
    16,482
    8,397
    Without reading the codes on the car, I can't imagine what could happen when it's cold that would prevent the car from starting. Maybe you have a bad brake light switch that acts up when it's cold? If this were to happen, it would have a code.
    I would make sure all your battery connections are tight and there's no corrosion on the wiring. Many Prius cars leak water into the 12v battery area
  6. ninaherrera
    california
    I actually took it to the Toyota dealer and it sat with them for a week and they weren’t able to give me a definitive answer. I just got back from autozone, installed a new 12 volt and still all lights come up as well as the check hybrid system but it doesn’t turn on. I have a 2005 Prius that I’ve never have had an issue with. This 2011 is draining my account.
    Thank you for the suggestion, I’m going to see if I can get a code reader.
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Hold down brake pedal, before you press the start button, check to see if the amber light is lit on the start button. If not lit, troubleshoot the sensor behind the brake pedal. If your battery is “good” then the issue is pedal sensor.
    If the amber light stays lit, then check the 12v battery terminals for corrosion and green stuff, clean if needed. Try to wiggle the terminal clamps, if they’re loose just hand tighten. Check the ground cable that connects from the battery to the car chassis also, it may have come loose over time.
    If all of the above checks out fine, check battery manufacture date. It’s typically a circle sticker with month/year- 12/2020. You may have to remove the battery completely to locate the sticker if it’s affixed on the side of the battery. If date is older than 5 years, replace it with a fully charged battery from the shelf.
    #7 Grit, Jan 30, 2021
    JC91006 likes this.
  8. dbstoo
    dbstoo Senior Member
    1,327
    703
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    How cold is "cold"? I had a 2002 gen 1 model that worked well for years, but on one trip to Lake Tahoe the temperature dropped to near zero. The car needed several attempts to get it to start. The local sealer said that there was a service bulletin that covered it. When I got home my local dealer replaced the ECM $$$$$ and the $20 relay called for by the bulletin. It worked fine from then on.
    There should be trouble codes available via the ODBII connector. That may be the best first avenue of attack.
    Dan
  9. ninaherrera
    california
    Thank you, it stayed lit. I’ll check cables tomorrow. I greatly appreciate it!
  10. ninaherrera
    california
    Not crazy cold, typically when it falls below 40. I’m going to look into that thank you.
