prius won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by darkrayne, May 27, 2015.
  1. darkrayne
    darkrayne New Member
    The dash lights are blinking. Outside temp says E. Doesn't always turn off. Afraid I may have a problem with the fob key?
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    the 12 volt battery in the trunk is the cause of most problems...remove it and have it tested, replace if needed, don't buy a used one and DONT charge it if still connected in the car, clean the connections and where the ground wire bolts to the body..good luck
  3. darkrayne
    Done all that. Read on YouTube. That out may be the inverter water pump
    49,735
    ahh, so.
  5. darkrayne
    Yeah trying to figure out what fuse controls that
  6. bisco
    49,735
    you may need to replace the pump.
  7. darkrayne
    Ok
    what's crazy is that the car doesn't want to turn all the way off unless I stick the FOb key in the slot and pull it out
    #7 darkrayne, May 27, 2015
  8. Beachbummm
    1,160
    392
    check them all with a meter it take less then 5 mins
    sounds like the washer fluid is low...the entire car is tied into the washer fluid...don't fall for the blinker fluid gag..the blinkers run on prayer
    #8 Beachbummm, May 27, 2015
  9. bisco
    49,735
    i thought it was the dome light.
  10. darkrayne
    my prius will not go into ready mode. the squares around the gear letters are blinking, the outside temp says E, the fuel pips are blinking. can someone please help me???
    also when i pluged in my od II it kept saying no link
    #10 darkrayne, May 28, 2015
  11. xliderider
    xliderider Senior Member
    7,895
    3,129
    Honolulu, HI
    Have you checked your 12v battery?
  12. darkrayne
    yes its brand new optima yellow top fully charged
  13. bisco
    49,735
    check the voltage, optima's have been off balance lately.
    darkrayne likes this.
  14. xliderider
    7,895
    3,129
    Honolulu, HI
    In another thread, there was a bad ground connection from the auxiliary battery to the car body.
  15. orenji
    orenji Senior Member
    5,884
    3,486
    It's a 2005, could be the battery pack.
  16. darkrayne
    Are you speaking of the battery itself?
  17. bisco
    49,735
    hybrid battery.
  18. darkrayne
  19. bisco
    49,735
    no worries yet, you need to have the codes read by a dealer, or someone with toyota tech stream.
  20. orenji
    5,884
    3,486
    Take it to the Toyota Dealer to properly diagnose the problem. Then take it to your shop of choice, if you can find one that will work on it for less.
