Prius won't start
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by wilsoncreek1861, Oct 4, 2018.
  1. wilsoncreek1861
    wilsoncreek1861 New Member
    Springfield, Missouri
    Drove my Prius to Sam's to have the tires checked and rotated. We figured on doing some shopping while this was being done. Minutes later the shop manager came looking for us and asked if there was a trick to starting the car, figuring that they hadn't put their foot on the brake, I returned to the car. Unlocking the car and getting in, sure enough when I pressed the start button nothing happened. My thoughts were "Battery has gone down" as the key lock worked and the alarm note when I put the remote in sounded. Is there anything else this may be?
    49,506
    you were probably right. test the 12v health, how old is it?
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Was the car in Park?
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
  5. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Maybe they left the doors opened, and battery drained?
    Does the ready light come on? If it doesn't, then to e for more digging deep! You
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Hmm...
    The easiest and first reaction is that it is the 12 volt battery. That should be easy to determine. But if this is true?
    If the battery could drain to problematic levels in just minutes, It probably was pretty weak to start with. Is it the original 12 volt battery? If it is, that would clearly be my first suspect.
    ztanos likes this.
  7. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    You didn't put a response. Was it in Park? If the transmission doesn't fully engage to Park then the car won't start. Everything else will work as normal. Could be a faulty neutral safety switch.
