Prius wouldn't boot up first two tries today
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fibb222, Dec 1, 2008.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
    When I pressed the power button on my Canadian 2004 Prius, the DRLs came on, the dash lights came on, the wipers (lever was left to on) tried to move but seemed out of umph, and the big triangle with the exclamation point was up on the dash too. Never seen it before.
    I turned off the A/C and Audio and powered down. I tried it again, same thing.
    3rd time was the charm, it went into ready mode like normal and I drove it all over town after that with nothing out of the ordinary, whats so ever.
    Was my 12v battery low?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    The 12v would be my first guess...is it the original?
  3. Fibb222
    Fibb222 New Member
    1,499
    99
    I betcha it is original, I haven't replaced it myself and I bought the car used a couple of years ago. I was just in for a major inspection. Wouldn't they have tested the battery?
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    if you experience 12v failure ( like you are currently ) you need to remove the 12v battery ( or disconnect it in spot ) and charge with a battery charger. there are amp warnings on the battery. if you have a 10a charger, you can use it to jump start your car ;)
    btw, i'm still using my original. if i fail to drive it for longer than 20 hours or so, it won't start.. hehe
  5. richard schumacher
    7,663
    1,038
    United States
    Evidently they didn't do a load test, and I wouldn't expect it unless they were told to do one. Most likely it's time for a new battery.
