  1. Keywall
    Keywall New Member
    Ireland
    hello everyoneGot 2004 priusIt shows these codes01-DC 1C6-F8-F01-CC 190-97-CThees codes ar from mfdisplayIt still drives , but power from hybr baterie is not going to engineHyb bat had one cell badwhich i replaceWhen i drive 10-20 km lights of the batery show on mfd and rew of t engineGo very hight and no power to driveWhen i stop swich off/on it drives againBoth baterry newThing its just minor errorTomas
    #1 Keywall, Mar 29, 2016
    49,506
    welcome! still the hybrid battery. what are you reading the codes with?
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Those are diagnostic codes for the Audio/Navigation system, you pulled off the MFD (Multi Function Display). mThe only meaningful information the MFD shows is the 12V battery voltage. But there are better ways to get the 12V battery information (ie, use of a DVM).
    You apparently did not know, or ignored the reality of module replacement: it does NOT work long term. Rebuit/Refurbished HV Battery packs have questionable longevity/reliability. The best long term reliability is a new HV Battery pack. Continuing to replace modules will leave you in a perpetual Ground Hog day.
    #3 exstudent, Mar 29, 2016
  4. Keywall
    Keywall New Member
    Ireland
    Thanks. Read it just from mfdisplay....jusr power from hyb batery its not going to engineNext week will now reading from main soo will see
  5. bisco
    49,506
    thanks for the update, all the best!(y)
