Priuschat folks are Crazy!
Discussion in 'Gen 2 Prius Main Forum' started by Cheap!, Jun 26, 2006.
  1. Cheap!
    Cheap! New Member
    1,157
    Or At Least I Am.
    I must be some kind of nut.
    I'm halfpint low on oil.
    Or, you could say I've got a little too much pressure in my tires.
    Here is proof.
    Regular
    [attachmentid=3940]
    Belly Pan
    [attachmentid=3941]
    Front Tire Spoiler Mod
    [attachmentid=3942]
    Rear Tire Spoiler Mod
    [attachmentid=3943]
    Way too much thinking about FE going on in here.
    Somebody help me. It a sickness.
  2. Cheap!
    Cheap! New Member
    1,157
    Ok, One more.
    [attachmentid=3944]
  3. slortz
    slortz New Member
    316
    <div class='quotetop'>QUOTE(Cheap! @ Jun 26 2006, 06:48 PM) [snapback]277066[/snapback]</div>
    How about, "your hybrid battery is bit overcharged." :)
  4. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(slortz @ Jun 26 2006, 07:03 PM) [snapback]277076[/snapback]</div>
    Good one. Is anyone else doing aero mods?
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I actually did move the front-wheel spats outward a little and
    angled back so they tend to flow air around the outside of the
    wheels more readily. I don't know if it did anything for the Cd,
    though. But where they are stock just doesn't make much sense.
    _H*
  6. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(hobbit @ Jun 27 2006, 12:31 AM) [snapback]277236[/snapback]</div>
    The front wheel spats actually create a pressure dam in front of the tire. That high air pressure then causes other wind flows to go around it and the tire. A side affect is that the high pressure under the car causes some lift in the front. If you were to remove the "spats" as you call them, there would not be high pressure in front of the tire and the tire would take the full impact of the wind. Think of it as an invisible shield that uses air to block air. There are better ways to reduce aerodynamic forces but they are not as visually pleasing to most people. However I like them.
    [attachmentid=3968]
  7. nerfer
    nerfer A young senior member
    2,507
    236
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(Cheap! @ Jun 26 2006, 10:48 PM) [snapback]277187[/snapback]</div>
    I haven't done any, but it seems to me there are 2 big areas crying out to be improved - the open belly, and the rear-view mirrors. I think it would be interesting to put a pan on the belly and put small cameras in place of the mirrors, with a direct feed to small screens just inside that little triangular window. The cameras would probably be 1/2" to 3/4" diameter, mounted maybe 3" out from the car.
