Priuschat Tire Pressure / Mileage Experiment
Discussion in 'Knowledge Base Articles Discussion' started by TonyPSchaefer, May 30, 2014.
  1. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Here's my idea:
    We get as many people as possible in as many different models as possible to carefully monitor their tire pressure and mileage to verify or debunk a correlation between tire pressure and mileage. Also, how much influence there is and at what point are there diminishing returns.
    I'm thinking it would work like this:
    Factory Default psi
    40 psi
    45 psi
    50 psi
    55 psi
    Everyone runs two tanks of "regular commute" at each psi. The higher pressures are for the brave.
    Here's what we need:
    • A way to record everyone's results
    • Everyone's vehicle model
    • Estimated city/highway percentages
    • Average temps for each tank to attempt normalization
    • Volunteers
    It won't be perfect because there are simply too many variables. But perhaps if we monitor only the delta and not the individual mileage, we just might see a trend.
    So:
    • Who's in?
    • How do we pull this off?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I certainly won't be part of suggesting folks exceed the max load rating of their tires. No amount of gas would relieve the guilt if even one accident resulted.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Did I mention voluntary? I meant to say "voluntary."
  4. joeman
    joeman Member
    239
    Raleigh, N.C.
    I will keep my o6 ,
    42 front
    40 back
    Won't be doing any calculating myself, My car gets Awesome gas miliage PERIOD.....
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Having the "Summer Blend" just released in Los Angeles, my MPG went up about 4 MPG! I am currently at 48.6 on 90 miles of back and forth starting Monday the 26yh May 2014! I run 44/42 F/R!! When the tires are at recommended settings, i lose about 3 to 5 MPG!
  6. bisco
    49,488
    i believe t/p makes very little difference. i would be happy to help prove/disprove my anecdotal evidence. i am so sure of myself, i run my tyres at 42/40.:oops:
    joeman likes this.
  7. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Tire pressure obviously make a big difference. We have to remember some people are running cheapie tires and mileage gains might not be so good for them ( higher rolling resistance, ect)
    I'm in, even though I know what the end result will be.
  8. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ...doing some Google searches on the topic a few weeks ago, saw some old (pre-2010) posts suggesting hypermiling expert Wayne Gerdes likes to use extremely high air pressure in his tires. I never get much higher than 40 myself. Does he have a website with some of this kind of info (effect of tire pressure)?
  9. bisco
    49,488
    i remember one guy posting that 10 psi = 10 mpg?(n)
  10. MSA14
    MSA14 Junior Member
    74
    23
    Metro Atlanta, GA
    I'm in. Currently run 40/38 on the factory yokohama s33's on a gen 3.
  11. bisco
    49,488
    i think we need danny's help, bob wilson, justin (fl8) and dianne whitmire.;)
  12. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    The more the merrier. It'd be nice to prove to all the haters that pressure is a contributor to MPG.
    To be honest, I wouldn't care it it got 40 mpg all the time. My ford 350 6.4 diesel got 11 mpg all the time.
  13. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    42 front
    40 rear
    Getting 55-65mpg on my 40 mile round trip daily commute (northern Illinois)
    iPhone ?
  14. Mendel Leisk
    38,726
    I have two ranges: ~38psi for the (OEM) 215/45R17 Michelin Pilots, ~44psi for the 195/65R15 Michelin X-Ice.
  15. ibmoses
    ibmoses Junior Member
    109
    22
    Found this thread while searching for tire pressure info...
    Newbie with a New 2013 Prius Two, has rhe Bridgestone Ecopia tires.
    Thinking of going 38f/38r or 40f/38r but really dont have a clue :)
    That sound like a good starting point to youse guys?
  16. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I drove from Buffalo, NY to Manhattan, then to Newport, RI and back to Buffalo..
    1079 miles. 22 gallons
    Average 49.0 MPG
    42 psi all around
  17. bisco
    49,488
    if you're starting from factory specs, now is a great time to try a tank at 2psi increments for ride, noise and mpg comparison.
  18. bisco
    49,488
  19. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Sold the prius -so no more tire BS for me. Just picked up my Tesla S. All electric 250 miles per "tank". Charges in 3 hours at home
  20. ursle
    ursle Gas miser
    1,049
    192
    NH
    So what's your tire pressure, you can be the "other" tester, try 30psi and run some distance trials, then 42psi and see if the distance doesn't increase by 10% or more, if it seems a burden I'd be happy to lend some time behind the wheel;)
    btw, it's not tire "bs" it's common sense
