priusshop - OEM quality fog light kit installation problem
Discussion in 'Gen 3 Prius Accessories and Modifications' started by gradybear, Jul 24, 2011.
  1. gradybear
    gradybear Junior Member
    16
    Southern California
    HELP! - OEM Quality Fog Light Kit Issues
    I just installed the fog light kit for my gf today which I bought from PriusChatShop.
    After the installation, I found out the lighting postion is different.
    (one side is slightly higher than the other side)
    How can I reposition the light?
    Also, the spacing between the fog light lamp and the gray plastic trim is different for both sides after i mounted them on my car.
    My driver side has much spacing compare with the passenger side.
    Is there a way to fix it ?
    Please Give Me Suggestions. And Thanks :canada:
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Search on here for OEM Fog Light and there are several threads on this subject. Spiderman has an excellent thread with a lot of pictures and explanations.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It needs some V8!
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    There is a screw underneath the light housing to adjust for height projection alignment.
  5. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    There are holes in the cover beneath the bumper right below the adjustment screws on each side. A long (8-12") phillips screwdriver will reach the screw. The screws might be tight.
