Problem - Red Exclamation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by stepha430, Jul 15, 2016.
  1. stepha430
    stepha430 Junior Member
    Hi there,
    I just turned on my car and received all of these errors. None of these alerts were on before. Please help with any insight you might have. image.jpeg image.jpeg
    Thank you so much in advance.
  2. JC91006
    16,480
    8,397
    Is this a 2006 or 2007?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Any issues prior to the codes appearing? How many miles? Tried reading the codes yet? Disconnect the 12v battery to reset?
    49,437
    that means you need to go to the dealer and have the trouble codes read. how many miles on her?
  5. JC91006
    16,480
    8,397
    You really shouldn't reset codes until you've tried to determine what the problem is.
    If this is a hv battery problem and you have 1 more day left on your warranty, resetting the codes would disqualify you in getting a free replacement during the warranty period
  6. stepha430
  7. stepha430
    No real issues prior. Have done the regular maintenance checkups.
    I did replace one of the batteries late last year.
  8. stepha430
    Around 130,000 miles
    About 136,000 miles
  9. JC91006
    16,480
    8,397
    If you are in California, you have a 10 year 150k miles warranty on the hv battery. I think you'll be getting a new one, just visit your nearest dealer
  10. stepha430
    Thanks! I am in California. Do all dealers know about this warranty? Do you think I can drive my car a couple of miles to the dealer or does it need to be towed?
    Is the "Problem" error mean it's not drivable?
    Thank you again so much
  11. JC91006
    16,480
    8,397
    I think you can safely drive a couple miles. Let us know the outcome
    Yes all dealers know this warranty
    What city are you in?
    #11 JC91006, Jul 15, 2016
  12. stepha430
    San Francisco.
    Just dropped it off said it's $175 to run a diagnostic on the car. Said to stay tuned
  13. JC91006
    16,480
    8,397
    $175 is highway robbery for a simple diagnosis of the warning lights.
    Either way, I think you'll be covered under warranty
  14. Patrick Wong
    18,200
    6,472
    Based upon the two photos in the OP, it is not obvious to me that the traction battery is at fault. If the OP had provided a photo of the MFD showing the battery icon in the upper left corner, then I would agree that the battery likely was the root cause.
    The check engine light could be on for any number of reasons, none of which would be covered by warranty. It is not clear why the VSC and ((!)) lights appear in the first photo but not the second.
    Raytheeagle likes this.
  15. JC91006
    16,480
    8,397
    Check engine light from bad catalytic converter, 3 way valve, and canister problems would be covered. Brake actuator and hv battery issues would be covered. I think op is fortunate to be in California to get the longer coverages
