Problem Replacing Map Light with LED
Discussion in 'Gen 3 Prius Accessories and Modifications' started by wdsh, Jul 23, 2010.
  1. wdsh
    wdsh New Member
    This was a newbie move, I admit.
    I got the lens cover off without problems.
    I twisted instead of pulled the bulb holder which unlocked it from the mount. Before i knew it, the bulb disappear into the top console, gone.
    Does anyone know how I can fix this? How does the light/glass console come down?
    Thanks,
    Will
    * I got the other bulb in without problems
  2. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    This should help...
  3. wdsh
    wdsh New Member
    Thanks so much, its fixed. but it wasn't easy.
  4. richard schumacher
    7,663
    1,038
    United States
    Whew!
    Which LED did you use?
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    be careful with the clips closest to you. They are in a piece of metal that is attached with double sided foam that pulled apart when I did mine. Can't get it to stick again, so mine sags down a bit.
    I had removed mine to install a homelink mirror.
  6. longhaul
    longhaul Junior Member
    25
    montgomery, il
    Richard: Did u get a answer to which lite was used? If so let me know. Thanks. Ron
  7. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Long Ron Silver, go to Sylvania's website. They list exactly what bulbs are used where. But I'm guessing it's a 194 wedge bulb for the maps.
