problem starting
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by southjerseycraig, Dec 3, 2019.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    So I put my foot firmly on the brake and push the start button. This always worked to get the "ready." Now the car just displays all of the warning lights, but I don't see the ready light. I have to try two or three times to get "ready" to go on. What's going on? Is something in the process of failing? Should I take the car into the shop before I drive it again?? Thanks as always!
  2. Mendel Leisk
    38,733
    Have you checked the 12 volt battery?
    Air_Boss and scona like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,980
    4,724
    Texas Hill Country
    Do you have a check engine light once it goes to Ready? Have you checked the brake light to verify 100% brake switch operation?
  4. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I don't have a check engine light once it goes to ready. When it goes to ready, it's fine. I Haven't checked the brake light.
  5. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    If in a garage, just watch to see if brake lights light up the garage door when you press on the pedal.
  6. bisco
    49,504
    did you read post #2?
