Problem with Apple Car Play on Gen 4 and iPhone
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Rapher, Dec 8, 2023.
  1. Rapher
    Rapher Junior Member
    Cincinnati
    2022 Prius
    I have a 2022 Prius. I am also still using an iPhone 8. For the past several months the Apple CarPlay feature will terminate for no known reason. I could be listening to music or using maps or charging my phone. First I thought it was my cable (after market Apple certified). This didn't make a difference. I thought it was a defect in the USB port in the center console (still under warranty). I took my car to the dealer, He told me the following. It was essential that I use an Apple Lightening cord to plug into the USB port in the console. Second, Toyota recommended use of iPhone 11 or later! I just replaced my cord with an Apple. Do you think this will fix the problem or might it be a defective USB port? Or is it my phone too old (the iOS system is up to date). Thoughts?
  2. Sharol
    Sharol Member
    130
    64
    Kansas, USA
    2023 Prius
    Your phone was manufactured around 2017. I had a similar problem, only it was on my 2012 Prius on bluetooth. It worked flawlessly until I upgraded my Galaxy in about 2015 or 2016. The newer phone refused to connect. A couple years later, after a phone update, it suddenly started working again. I def. would get Apple's cable. Have you run all he updates for the phone?
  3. I Throw 99
    I Throw 99 New Member
    28
    2023 Prius
    XLE AWD-e
    My experience is that Carplay is VERY picky about cables. In my aftermarket carplay unit, I often have to change cables to solve the issue you are describing. The cables work perfectly fine for other things, but Carplay doesnt like them. I finalky resorted to keeping a few cables in my car, and just swap through them when Carplay keeps disconnecting.
    In my Prius, I use wireless carplay, and the disconnect issue has never happened.
  4. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    On our Gen4 Prius that I traded in for a Kia Niro, I used a cplay2air gizmo plugged into the usb port to give me wireless CarPlay. Took maybe 10-20 seconds to connect. Flawless — may have had to remove and plug it back in a couple of times. I highly recommend it.
    the same gizmo worked in our Niro until some random software update in the Niro, and then stopped working. I bought another one (newer! Shinier!) and that one is now working flawlessly.
