Problem with creep?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Noobius, Jul 3, 2018.
  1. Noobius
    Noobius Junior Member
    Boston
    I have an '05 with about 191k and the last year or so I've had an issue where the car jerks and lurches at low speeds, just before coming to a stop. Originally I thought it was an ABS issue but over time I've come to suspect the "creep" is cycling on and off, like the car doesn't know how hard I'm braking and when to disengage creep.
    Anyone else experience something like this? If I come to a stop in neutral the lurching doesn't happen. I was wondering if a failing stroke sensor could cause this? I'm really not very familiar with the Prius' unique brake system so I'd appreciate any light you folks could shed.
    I'd really like to fix this issue since not only does it seem like it's wearing on the car, it also makes me look like an idiot coming to a stop. The car didn't do it at all when I first bought the car at 166k. I've verified that all four wheel speed sensors are working properly which is why I ruled out the ABS system plus the jerking/lurching is fairly slow, maybe twice per second and ABS usually cycles much faster than that. But I could be wrong!
  2. Noobius
    Boston
    Also could it be the regenerative braking is turning on and off instead of smoothly transitioning to the hydraulic brakes?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Odd issue have not seen that here. The fact that when in neutral it stops ok is def drivetrain.
    Bottom line is does it have the original hybrid battery in it? Because if it does that’s over shadowing every financial decision you will make to fix this problem. Meaning don’t put alot of money into the car until you make a decision on how your going to fix that battery when it dies because it will soon.
    That’s all we see here now is dead g2 hybrid battery’s.use the search forum button up top and search
    Hybrid battery
    Back to your issue. If it was me I would start tuning the car up. What’s been done tune up wise ?
    Plugs, hoses , engine coolant ,inverter coolant ,transmission fluid. Brake and cv joint inspection.
    It’s strictly mechanical because it’s not throwing any dash or mfd codes. But sometimes working on the car and checking it out you will discover issues.
    #3 edthefox5, Jul 4, 2018
  4. JC91006
    16,479
    8,397
    You might just have some build up on your brakes. Try going 40 mph and stopping in neutral really hard a few times.
    How's your engine maintenance? Clean the throttle body lately? Check oil and air filter?
  5. bisco
    49,430
    are you going to diy? if so, pick up an inexpensive (under $100.) prius aware code reader and start with the trouble codes.
    Raytheeagle likes this.
  6. Noobius
    Boston
    Brakes are clean, I do the neutral brake thing every couple of days and plenty of meat left on the pads and shoes. I changed the ATF with OEM fluid and changed the spark plugs. I haven't changed out the fluid in either of the coolant systems yet but they're both full and look clean. I change the oil and rotate tires every 5k. I have a laptop with Techstream and I don't have any codes at all. The car thinks everything is okay.
    I'm sure the battery will fail me one of these days, I already have noticed that the battery meter is "correcting" itself every now and then. One minute I have 6 bars of battery and two seconds later it's dropped to 2 bars. But it's been doing that for quite a while and still no warning lights. I plan on getting a Green Bean battery when it finally dies, $1500 gets you a 5 year warranty and they install it in your driveway. The 12v battery checks out as okay.
    Now that I've been thinking about it I do wonder if it's the regen braking that's the problem. Instead of just letting go and having the hydraulic brakes take over it keeps pulsing on and off from about 5 mph down to a full stop. Doesn't always do it, some stops are normal but it often does do it. I was hoping it was a sensor issue or something easy to fix. I loathe the idea of taking it to the dealer, partly for financial reasons but also because all I ever hear from them is "we can't duplicate the issue".
  7. edthefox5
    10,096
    4,805
    Clearwater, Florida
    If its just the brakes there going to do it when in neutral I would think. Maybe a video.
    fotomoto likes this.
  8. edthefox5
    10,096
    4,805
    Clearwater, Florida
    It may be beginnings of abs failure. But it would throw a lot of codes.
    Take pictures of front rotors and post them. Let’s see how bad they are. Usually if there’s mechanical issues you will know it as they make alot of noises.
  9. JC91006
    16,479
    8,397
    I get the feeling described by the OP sometimes, but it's usually dirty rotors after my cars been sitting for a couple weeks. Some hard stops in neutral usually is the cure
    edthefox5 likes this.
  10. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Agreed. But op not complaining about scraping noises but never heard his particular complaint so your probably right.
    Get it up to 65 mpgs no one behind and put it in neutral and Apply brake firmly. Repeat.
    Let’s see if he replies to my post #8 and we can see the rotors. There probably wiped out.
    JC91006 likes this.
  11. Noobius
    Boston
    Hey guys, don't mean to revive a dead thread but I finally fixed the problem. I did three things this weekend and one (or more) of them completely fixed the problem. I bled both rear brake lines (didn't see any air bubbles come out), I reset the ABS computer memory and lastly I recalibrated the "linear solenoid valve offset". Not sure if I quoted that exactly right but it was an option in TechStream so I figured why not? Today the car stopped like a normal car, no pulsing of the brakes at all.
  12. bisco
    49,430
    congrats, well done!(y)
  13. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Glad your back in the mix, and everything worked out.
    How is your HV battery holding up?
    Could you also tell us what was involved in recalibrating the "linear solenoid valve offset" via techstream?
  14. ChapmanF
    15,560
    You park in a level place where the car won't roll with the parking brake off, and you tell Techstream you want the car to learn the solenoid offset, and for about a minute you listen to the valves clicking and making faint pfffsst sounds and then medium Pfffsst sounds and then louder PFFfsst sounds, and then the light blinks quickly and it's done.
    Skibob and SFO like this.
