Problem with electric motor or hybrid system?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sordospilot, Aug 27, 2015.
  1. Sordospilot
    Sordospilot New Member
    San diego
    i bought 2008 Prius touring few days ago. It is 123k miles. I have been rent Prius many times. Until I have own Prius, and I noticed the behavior are stranges. No any warning lights.
    I got 38mpg in 41 miles. It is poor performance. Most it would be normal if it showed 45mpg to 50mpg.
    I notice it have use gas engine all time to charge battery. When battery full then they still use gas engine. It have rare use electric motor. It let use electric motor go to 2 mph then gas engine take over.
    Can you tell me what trouble cause come from?
  2. ChapmanF
    15,630
    There are a lot of possibilities. If you have something like a ScanGauge, the Torque app for a smartphone, or the Mini VCI scan tool, you can watch a lot of things as the car runs, such as current in and out of the battery, state of charge, engine output, and so on. Without such a tool, it is difficult to perceive all that is going on with enough specificity to make diagnoses.
    It is good to avoid the mistake of thinking only of hybrid-specific problems. The car has some specialized hybrid components, but there is the whole rest of a car attached to them. Even something as simple as dragging brakes will make the whole thing work harder, and the symptoms would be as you describe. All of the possibilities, including the simple ones, are worth thinking about. (Speaking of brakes, are your rotors warm or hot at the end of a drive? I'm not saying it has to be your explanation, but it's really fast to test.)
    Regards,
    -Chap
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Since you just bought it, I would recommend doing the requisite maintenance before concluding that the hybrid battery is going bad. People tend to let slip the maintenance requirements of a car that they are going to sell because it is going to be somebody else's problem.
    After the maintenance is done, then I would run a couple of tanks to see where the fuel economy stands.
  4. DHonzik
    DHonzik Junior Member
    70
    Oak Creek, Wisconsin
    I had the same thing happened to me, I started noticing the mileage during the summer was not where it was suppose to be and at 138,000 miles one cell block in battery went weak. $1800 later, I had my battery reconditioned and balanced. By the time of the lower and not expected mileage and battery failure was about 4 months.
  5. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Its a shame you didn't buy a 100% BRAND NEW Toyota HV Battery for $200-$400 more ($2,000-$2,200), from a Toyota dealer who sells online. You would have to find an online Toyota dealer near you, and make sure they will sell to you, as some dealers are being lame and won't sell to the public; illegal in my opinion and needs to be challenged in court, b/c if safety was a legitimate issue, they should not sell brake parts and suspension components to the public as well.
    You would have to DIY the install, or pay someone to do it for you. Swap out the various components the New HV battery won't come with (various ECUs).
    There is a member (Kinglew), in my opinion a conspiracy theory nutcase, who believes Toyota sells rebuilt/refurbished HV Batteries, despite the laws distinguishing NEW vs used/rebuilt/refurbished. He/she is the only one who believes this. I encouraged him/her to stand by their conviction, and contact one of the big law firms that sued Toyota in the Class Action lawsuits over sudden acceleration, to start a new Class Action. If his/her fairy tale beliefs were even remotely true, the Law firm would do so, b/c there would be big $$$$ to be made, for the firm and the initial claimant. Alas, all bark from that individual.
  6. Sordospilot
    San diego
    I have replace new 12v aux battery (yellow top) and it solve for few days then it come again later. It showed image that I saw it and I have to disconnect negative from 12v battery then it solve but it come again later. Does it happen to you before?
    What else I need to check or replace part?
  7. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    You need to read fault codes. If you want to do it yourself get the Mini-VCI.
  8. Sordospilot
    San diego
    Which mini-VCI you recommend that work with Prius?
  9. bisco
    49,500
    the one from amazon.
  10. bisco
    49,500
    i wonder if something is draining the 12v
