Problem with my brakes.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CreepingDeath, Dec 21, 2012.
  1. CreepingDeath
    CreepingDeath Junior Member
    Gresham, Oregon
    Sorry in advance for the long post and the incomplete details.
    I was waiting for my son to come out of his work for an hour with the car on. I got distracted reading and messing around on my phone, and since the heater and lights were off, I had no incentive to turn the car off since it was perfectly quiet (the gas motor only kicked on once to keep the battery charged). Then, I can't remember if I turned the car off or left it on while I took a nap for an hour (he was a total of two hours late getting out of work). At any rate, when he finally came out, I don't remember if I needed to turn the car on, but I do remember that as I pushed the brake down, put it in reverse, and began to back out, I was moving kind of fast and pushing the brake down didn't slow my motion at all. Also, it felt like there was not much resistance in the pedal. I stood on the brake and there was a noise and a jolt as I came to a stop. I really thought I had stopped because I hit something, that's how violent the stop was. But my son walked around the car and found I had not. No dash warning lights came on. I pushed the park button, powered the car off and on, then put it in drive and coasted forward / carefully tested the brakes. All was good. I put it in reverse and used the brakes without anything seeming out of the ordinary. Then we drove 16 miles home with no issues. Until this incident I have never had a single brake-related issue apart from grabby brakes when it is raining.
    From reading some posts here, this is what I have learned:
    When I stood on the brakes, that is the only time the hydraulic system was in play.
    Rusty brake components are pretty grabby.
    Actuators are expensive and no service center wants to replace them at 92K miles.
    I assume that the violent stop was due to the hydraulic system engaging and the brakes being grabby.
    I wonder if the fact that I had the car on so long contributed in any way to the problem. It was either on for an hour then off for an hour, or it was on the whole two hours.
    I wonder if I could have an actuator leaking by, whether it could be an intermittent actuator problem (does it always fail hard, is there a symptom that gets worse over time, etc.) , or whether it is an isolated incident, and how to know. Could it be another component, and how do I test for that? With the car off, I hear the actuator pump come on for a few seconds every time I push the brake pedal down and let it spring return. I seem to hear it come on once in a while when I'm driving; is that normal? If so, how often is normal, roughly? I worry that having a wait-and-see attitude could make for dangerous driving situations. I would take it straight to the shop except for the fact that I am unsure whether this is an isolated incident caused by me having the car on and in park so long. I would appreciate any and all feedback, thanks in advance for the help!
    BTW: Not sure if it's important or a coincidence, but I had spent the whole day vacuuming / detailing the interior. Maybe I created a marginal electrical connection somewhere?
    Longinus876 likes this.
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    In reverse at the speed you would be traveling only the hydraulic brakes would be working as regen braking only works above 7 MPH. If you hit the brakes hard the brake system does have an emergency brake assist and it is possible this is why you came to a sudden stop. If there was a problem with the brakes they should have set a fault code. The actuator pump sound is normal, it is possible if your 12 volt battery was low due to your being parked with some load on the battery (radio ect) the actuator pump is driven by the 12 volt battery and the pressure could have been low thus giving little assistance.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Interesting indeed.
    You were reversing so as long as you were under 7mph, there would have been no regenerative brakes anyways as it is under the speed cutoff.
    So the hydraulic brakes should have been engaged at various pressures the whole time. The system should be primed and under pressure at all times. The car even does checks on the pressure in the lines routinely while off and while on. it is also done everytime you open the driver door.
    Just throwing out possibilities, but could your leg perhaps have fallen asleep? Then your sense of pressure applied would be wrong until you jammed your leg instead of your foot. I have heard of it happening before, and 2 hours sleeping in one position upright, would be enough for my leg to fall asleep.
    If there was a recorded anomaly in the braking system there should have been a code thrown and a triangle sent. So either there was no anomaly and it was responding as normal, or there is a severe fault that prevented a warning even with all the check systems in place.
    With the brakes you do have manual control with the hydraulic line even if there is no power. Of course this only applies if there is correct pressure in the lines or you are just moving air around. Have you at any point had the brakes bled? Done yourself or taken to a non-Toyota mechanic for brake changes or anything like that? The Prius system is unusual in that it is never dead when off. You have to pull some relays to kill it, then you can do your brake job. This conflicts with 99.9% of the vehicles out there, so your average non-Toyota mechanic and the majority of DIY'er don't realize this. Best case, nothing bad happens and you do your change inbetween random and live pressure checks. Worst case is it shoots a caliper through your hand.
  4. Britprius
    5,194
    1,921
    To check the hydraulic brakes out, find a quite section of road, drive at 40 MPH select neutral and brake normally, "this will cancel regen braking". If all is well the car should come to a normal standstill under full braking control. If there is a problem you can shift into drive and brake again this will bring in the regen brakes.
  5. fuzzy1
    10,515
    OP's description seems to fit an infrequent but persistent pattern of reports here. It is as if the power assist / brake-by-wire system momentarily fails, without triggering any warning codes. This is different and far less common than the forward 'brake surge' or 'bump dropout' issue that prompted a recall of the 2010s (and still exists at a lower level), and the reverse grabbiness / over-sensitivity issue. But similar reports keep popping up here, without resolution. I had two events in my 2010, but resolved them by cycling power before thinking about observing or collecting enough information.
    Federal safety regulations define how well brakes must perform when any portion of the system, including the power assist, fails. With a certain (brute force) pedal pressure, the vehicle must still stop within a certain (long) distance from a certain (highway) speed.
    By standing on the brake pedal, OP did the right thing, manually pushing through to the underlying hydraulic system which worked as required. Other posters here indicate that the brake pedal fell close to the floor and felt dead, but didn't give a useful indication of how much pedal force they applied. Some sound as if they applied only regular braking force, which is quite inadequate for manual override braking. Others may or may not have been at or near the 112 pounds of the federal test.
    In previous posts, I kept harping that in such events, drivers must apply at least 112 pounds of pedal force. In any car, not just in a Prius. Failure at that pressure is prima facie evidence of violating federal safety regulations, which would force a recall. Failure at lower pressure can be a legal operating mode.
    Lesser failures could also trigger a recall or TSB or design fix, but reports and evidence are still too scarce to point to anything. So please consider filing a defect report with NHTSA.
    When I have more time, I'll dig up links to previous discussions.
