Problem with Scan Gauge MPG'S
Discussion in 'Gen 2 Prius Main Forum' started by sandman, Aug 15, 2008.
  1. sandman
    sandman Member
    277
    32
    kentucky
    OK got my scan gauge II been using it for a week now, but after getting gas and changing the amount of gas I actually pumped versus what the SG2 said my MPG"s have been way off. Is there a way to adjust them ? The instant MPG's are correct but the Current Fuel Economy and the tank MPG's are way off. I am 400 miles into this tank my MFD shows 61.2MPG and the SG2 tank MPG says 50 MPG . I was at 60.6mpg when I left work and it went up but when I got home my CFE showed 44.6mpg and it all started after the second fill-up ..any help would be greatly appreciated..thanks
  2. mnky357us
    mnky357us bweverka
    42
    Cornelius, Oregon
    This in no way answers your question, but one I have about the Scan Gauge also.
    My brother and I both have 2008 prius and both have scan gauges, well mine is
    off on the MPH about 1 mile per hour, my brothers is off about 5 to 7 miles per hour.
    Does this mean that if it is off that far how far off would the rest of its readings be?
    Thanks for any info....
  3. sandman
    sandman Member
    277
    32
    kentucky
    I Thought I had my problem solved I went back to factory presets and gauge was good then I re-calibrated it (filled up at same station twice didn't make any changes until second time) but my current fuel economy is off again ..:( it was correct until second time filling up I changed the amount of gas I put in . I am going to wait until next fill up and see if it fixes it. The only thing I can think is the first time I got gas was in the cool morning this time it was 93 degrees maybe that is what did it..
  4. ivanbg
    ivanbg Junior Member
    Alexandria VA
    When you dived the gallons filled up with the miles traveled which gauge is more accurate?
  5. richard schumacher
    7,665
    1,047
    United States
    A man with one watch always knows what time it is. A man with two is never certain.
  6. ceric
    ceric New Member
    1,114
    Fremont, CA
    A man with two atomic watches always know that his watches are within 1 second to each other. ;)
    I have ScanGaugeII on my Mazda CX-9. It lacks a trip computer so I use ScanGauge instead. After calibration, it has been very accurate. So, maybe the inaccuracy is related to hybrid system? Just a thought.
