Problem with SKS sensor?
Discussion in 'Gen 2 Prius Main Forum' started by rhodson, Sep 29, 2006.
  1. rhodson
    rhodson New Member
    I'm a new Prius owner, just turned 1200 miles. I have a question about the smart key door unlock. It seems to be almost instantaneous when I touch either of the front doors. However, there seems to be a 3-4 second delay when I touch the back hatch. No big deal, but somewhat annoying. I'm wondering if maybe I have a bad sensor back there, or is this a common problem.
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I think it's supposed to be that way (if not, then i've got a problem too!) the difference, i believe, is the way the sensors were designed. the ones on the door handles are extremely sensitive, and go off the second any pressure is applied (they'll go off while washing your car from the water if you've got the fob in your pocket!). The hatch, however, seems to be more of a standard switch... you've got to sqeeze it until the button depresses far enough to trigger, not just touch it.
  3. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    <div class='quotetop'>QUOTE(SparkyPrius @ Sep 29 2006, 10:04 AM) [snapback]325639[/snapback]</div>
    On the two front doors, no pressure is needed--it responds simply to touch. The back hatch, however, requires that you actually press the area as though you were going to open it--it will unlock immediatly when you put sufficient pressure on it, and then you press again to actually make the hatch lift. do not know why they did it that way....
  4. Tideland Prius
    16,066
    To refine both eagle's and mcbrunnhilde's response, you don't even need to touch it. Try it! Place your hand in the cavity close to the handle but don't touch it. It'll unlock.
    With regards to the hatch, press once and it'll unlock so you have to physically press the button. Hold it to unlock and the release the hatch (or press twice, once to unlock, once to release the hatch if you don't like holding)
  5. rhodson
    rhodson New Member
    Thanks guys, that's what I was doing wrong. :)
