1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Any one please help me on this pleas ..
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Does the engine start now? If it only runs for 10 seconds it’s not actually running that’s just cracking.
    Press the snow flake icon on the software and check the information from the time faults happened. Post all information from bough fault codes here.
    When it’s trying to start (or is running) does the exhaust smell like fuel?
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    What year Prius is this?
  4. Nme619
    Nme619 New Member
    San Diego
    Have your Catalytic Converter checked at at reliable muffler shop, not the dealer...if you live out of California you should be able to replace the Catalytic Converter for a couple hundred bux.
  5. Mendel Leisk
    42,219
    You guys must be viewing on a phone, lol (been there). It's a 2005, and he's in Phnom Pehn (Vietnam?).
  6. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    The engine start as normal but it likely smell fuel. So what the real problem is
  7. Patrick Wong
    18,210
    6,517
    OP is in Cambodia and probably has a JDM model.
    DTC P0172 means the engine is running too rich. A leaky fuel injector is the most likely possibility. A faulty mass air flow meter is another.
  8. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Patrick you are right it a faulty mass air flow problem . It was too much dusty and make the engine running not smooth . By the way thank all for help God bless you guy
