Problems after ABS replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by refusedone, Jun 3, 2023.
  1. refusedone
    refusedone Junior Member
    34
    los angeles
    I’ve changed the brake booster assembly, my brake lights are stuck on & can’t put it in “ready off” mode
  2. JSB_99
    JSB_99 Member
    66
    48
    Houston
    Sounds like you need to adjust the brake light switch attached to the pedal. Someone else before has one that would not go into ready mode and the lights would not work and that was the issue.
    refusedone likes this.
  3. ChapmanF
    18,257
    That mode's more officially called "IG ON" mode.
    So you have OFF, then ACC (one button press, no brake), IG ON (second button press, no brake), and READY (button press, brake).
    Those are the names most PriusChatters will know.
  4. refusedone
    34
    los angeles
    yes that was the issue, thank you!
  5. refusedone
    34
    los angeles
    Thank you for all your help along the way, I got the new unit installed & all is well, thanks to your help & the priuschat community, thanks sgain!
