Problems going into reverse
Discussion in 'Generation 1 Prius Discussion' started by Colin Elvey, Nov 21, 2013.
  1. Colin Elvey
    Colin Elvey New Member
    Melbourne, Australia
    1999 Prius
    Hi Guys/Gals,
    My Prius is having issues going into reverse.
    Sometimes it goes in fine and smetimes it wont go into reverse at all making it basically unusable as it has become too unreliable to use on the road.
    Any suggestions on how to fix would be appreciated.
    Cheers, Colin E.
  2. Patrick Wong
    18,200
    6,492
  3. Tideland Prius
    16,445
    Do you have a Gen 1 or Gen 2 Prius? It appears you have a Gen 1 based on your profile. (i.e. a Japanese import). Is that right?
  4. YOLOsoBuyaPrius
    YOLOsoBuyaPrius Junior Member
    77
    Nebraska
    Is it not shifting? or is it not accelerating? if it wont shift there should be a button under the steering wheel covered by a rectangle/square, you just push it and it shifts again. If it is not even accelerating you need a new HV battery because the computer has decided that the battery is too low to draw a current from. (the electric motor makes it reverse) You can force charge a Prius by placing one foot FIRMLY on the brake and the other on the gas while in D and it will run the engine at a fast speed. This is for 1997-2003 Prius.
