Problems with brakes
Discussion in 'Generation 1 Prius Discussion' started by Mace William Scovell, Feb 21, 2021.
  1. Mace William Scovell
    Pennsylvania
    So about a week ago I had a check engine light pop up on my dash, so I left the car running and ran in to grab my OBD reader. When I came back I pulled the code and noticed that the ABS and VSC lights were freaking out, so I restarted the car and the ABS, VSC, and brake lights were all on. I've also noticed that the breaks seem to be sticky, like they're holding on longer than they should. I did have the car running when I pulled the code, if that makes a difference. Anyone have this issue before?
  2. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Does your OBDII reader pick up anything other than OBDII codes? And what codes did you actually get? Asking people if they've ever had a check engine light and/or ABS-VSC lights come on is basically a big - sure. But the lights don't say anything specific. The codes do.
  3. Mace William Scovell
    Pennsylvania
    The two codes my ODB reader are pulling C1203, and C1345.
