Problems with dimmer switch?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scornfulsaint, Dec 22, 2009.
  1. scornfulsaint
    scornfulsaint New Member
    colorado
    I have a 2005 Prius. When my headlights are on, the instrument cluster with the speedometer etc and the mfd are lit up so I can see. The buttons on the steering wheel and the cd/stereo control buttons are not lit up. I tried turning the dimmer switch but the buttons lights flicker a little but barely enough to see or they remain dark. The speedometer display goes dark or lights up when i turn the switch.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The lights on the steering wheel are not affected by the dimmer wheel. They are always on when the headlights are on. However, they are very dim and can only be seen when it is quite dark. There is no brightness adjustment for them.
  3. scornfulsaint
    colorado
    what about the buttons for the cd/stereo controls and the buttons around the mfd (climate, audio,..etc...)? I have the same problems with them...as I turn the dimmer switch they light up very faintly then they go out.
  4. Ali921
    Ali921 New Member
    Chicago
    I have a similar issue. Did anyone ever figure out why this is having an issue. Or how easy it was to change the dimmer switch?
  5. Damncold
    Damncold Newbie
    Same issue with my 2006 Prius -- must have dimmer all the way ON to see anything. No lights on radio at all. Scrolling dimmer wheel down = all goes black. Help!
  6. bisco
    49,455
    welcome! sounds like a bad switch. if you don't get any response here, try starting a new thread. all the best.(y)
