Problems with my 2008 Prius
Discussion in 'Newbie Forum' started by My Milo, Sep 24, 2016.
  1. My Milo
    My Milo New Member
    Cape Coral, Florida
    Day started out fine until all the warning lights came on all at once. Never had a problem with this car before. I was so far from home that I started to look up some of the warning light descriptions and decided that it was probably the battery and I might be able to make it home. The only problem I could detect was that I lost my cruise control and my A/C. Other than that the car was driving fine and there was no noise. Then the brake light started to come on, and then buzzer went off, this would happen about every 40 miles. Then the car started to shift into neutral and I was losing power. I was able to shift back into drive but even that ability was soon gone. I was 7 hours from home and left with no choice but to find a hotel fast and spend the night until someone could come get me and tow the car home.
    So my question is this.......is this the fault of my 12V battery going bad? When I looked at my display, I still had a lot of blue bars. I have read where Toyota says it is impossible for the car to shift into neutral, but it can and it did! I was also losing my brakes.
  2. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Yes, check the 12v battery. The number of bars has nothing to do with it. If in doubt, change it out.
    49,521
    welcome! how many miles on her? original 12v? check inverter fluid reservoir for movement as well.
  4. My Milo
    My Milo New Member
    Cape Coral, Florida
    Has 81,000 miles on original battery. Would this have caused all the problems I was having....with the car shifting into neutral?
    And where would be the best place to purchase the battery. I'm a DYI type of person and have handle most of the minor repairs to the car myself. I checked on Amazon and they have the battery for about $150.00. I've checked out u-tube videos and I'm pretty confident that I can handle the replacement.
    What will that tell me?
  5. bisco
    49,521
    you need a digital volt meter to test the 12v battery at the jump terminal under the hood, after the car has been off for a few hours. it should read 12.4 volts or better, and a low battery can cause all kine of funky things to the computers which control everything.
    the inverter fluid in the reservoir should have movement when the car is in ready. that is just another possibility, if the battery is okay.
