Problems with no check engine light. Help!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Japanwins 2013, Aug 2, 2018.
  1. Japanwins 2013
    Japanwins 2013 New Member
    Apple valley California
    My 2007 prius has given me 5 years of perfect driving. Now at 160k miles it is giving numerous problems with absolutely no check engine lights. Or warning lights of any kind. Even the mechanics at a reputable shop whom specializes in prius are stumped.
    My problems..... In order of occurrence..
    The car at start up is at 1 bar of battery, instead of turning the engine on to charge it, the car only turns the engine on when the throttle is pressed, then immediately shuts off, the battery would not go higher than 2 bars the entire drive due to not being charged properly.
    At a dead stop, the energy monitor shows the engine on, and powering the wheels, and battery.
    Engine idle is very low, with a slight vibration, battery is at 5 bars yet the engine will not turn off, rather it shows that the car is charging the battery.
    Last but certainly not least...
    The car was driving fine, then from a stop light on, you press on the peddle, even to the floor, yet the car is completely unresponsive, then after approximately 5 seconds, the car gives a hard kick, accelerates a little, unresponsive, kick, then a very rough acceleration up to cruising speed.
    This problem is randomly occurring now, at times the car drives fine, except for previous odd behavior, then without notice or pattern. This again.
    This website is my last option. Seeing that as I said I have no lights, and even the mechanics being stumped.
    Please, please, please. Any advice helps!
  2. Dbryant1732
    Dbryant1732 Junior Member
    40
    Clarksville, TN
    I am still learning about the Prius and Hybrid technology, but I am educated about cars. This almost sounds like a deep electrical issue that you are having. A lot of the times electrical issues will not throw a code on the dash. There is def a miscommunication somewhere in the CPU of the car. I would take it to a Toyota dealership and have them hook it up to a computer, they will have a car scanner that can read the entire car, to include any blown speakers, that would be able to trace the problem more thoroughly.
    Japanwins 2013 likes this.
  3. Japanwins 2013
    I will take it in today, thank you for the advice!!! Very much appreciated.
  4. JC91006
    16,827
    8,600
    What have you replaced on the car? If you've ever replaced the HV battery, I would suspect that would be your problem
    Japanwins 2013 and johnjohnchu like this.
  5. Japanwins 2013
    It still has the original. While taking into Toyota it gave a new symptom. It did notnot want to stay in drive. At a stop it would consistently shift itself out of drive or reverse and into neutral. After approx 5 tries it would stay in drive until you stop again.
  6. Japanwins 2013
    The only thing I have replaced is the 12v. Which I checked and is fine. And the engine water pump.
