problems with Optima D51 yellowtop
Discussion in 'Gen 2 Prius Main Forum' started by LIPriusFreak, May 24, 2012.
  1. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    been having problems with my optima yellowtop that is less than 1 year old. Sometimes my car starts fine, sometimes it won't until I jump it.
    Spoke to Bernie from elearnaid (who I bought it from) and he says with my short driving habits (10min to work, 10min home) that the battery isn't getting a full charge from my engine because of the short commute...
    also now my immobilizer (smart key) won't unlock doors without using keyfob or start car without keyfob in slot...
    he told me to trickle charge it for 18-36 hrs...
    anyone had this with an optima?
    I have an 06 prius fully loaded
  2. usnavystgc
    3,159
    989
    Tucson, AZ
    My commute is similiar to yours and I don't have this problem. I am on the original traction battery though. I do have the optima in my '01 and my son has a similiar commute as well. We have not had any issues like this on it either.
    If I were in your shoes, I would put the battery on a charger and watch it charge (not literally but monitor it). I have a Schumaker charger that lets you watch the charge percentage rise as it charges. I have heard that short trips do not allow the battery to fully charge but, I haven't personally experienced any problems.
  3. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    We have a gen3 with the OEM battery, but I'm responding since I have a short commute.
    We have a 1.5 mile commute, but do a fair amount of additional driving most of the time. When that's not the case for a while, I use a BatterMinder Plus overnight.
    Measured under the hood or on the NAV screen, voltage looks low (11.7V on NAV), but measured at the battery itself, resting voltage is 12.6V after sitting overnight even though I have not used the BM+ on it for months now. Wondering if I have a poor ground to the NAV's measuring point?
    We have had no problems, but I think our battery was struggling a bit prior to using the BM+. We've had the car 2.5 years and gone 34,000 miles.
  4. flim
    flim Active Member
    207
    141
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    My wife's 07 Prius with a month old Optima battery stopped working last night and I had to jump the battery. She barely use the fan while parked outside the mall when it happened.
    I drove it home around town for awhile and did the diagnostic on the Prius Display. It showed 12.4 v when I turned on the Acc and increased to 14.1 when I powered on. The battery should be fine.
    She also has very short trips to the office less than 1/2 mile and we rarely use the 07 or for longer trips after we got the 2012 PIP.
    It's never healthy for the battery or engine with those short trips and left unused or little use for days.
  5. LIPriusFreak
    449
    34
    Long Island, NY
    YAY! not only me had this issue! was beginning to think I lost it (well, that might still be true but....) :)
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There was a bad batch of Optima batteries. Keep a eye on them. Short trips should not drain the 12V battery. Almost no charge is used to start the car. Do check for lights left on. The hatch light is the most likely to be left on. It's hard to tell it's on in daylight.
  7. richard schumacher
    7,663
    1,038
    United States
    Hoary old question: do you *always* lock the car?
  8. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    The hatch light should automatically go off when hatch is closed, even if the hatch light switch is on.
