Problems with Pioneer AVH-501EX
Discussion in 'Gen 2 Prius Audio and Electronics' started by donzoh1, Apr 5, 2022.
Tags:
  1. donzoh1
    donzoh1 Active Member
    440
    151
    Lenexa, KS
    My 2007 has an after market Pioneer AVH=501EX. I didn't install it. I have 2 basic problems. First, the AM band is pretty much unusable due to static/interference possibly with the cars's electrical system. Second, it will not connect with Bluetooth because it thinks the parking brake is not on. Are there any pins or wires that I can jump to defeat this feature or can the radio be programmed to eliminate it. I don't know whether the brake switch works but the parking brake does work correctly.
  2. Taylor8682
    Taylor8682 New Member
    HUNTSVILLE
    What wire color is the parking brake from the stock radio?
  3. ColoradoCrow
    ColoradoCrow Active Member
    973
    392
    Leawood, KS
    I
    My wife has a Pioneer unit. IIRC the purple wire needs to be connected. There is a new $9.99 in line resitor you can buy to fool the radio into thinking the parking brake is on. Its called a parking brake bypass.
  4. ColoradoCrow
    973
    392
    Leawood, KS
    I
    Actually It is LIGHT GREEN. Sorry for the mistake
