Production 2012 Prius Plug-In Set for Frankfurt Debut - 77% increase in MPG
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Aug 12, 2011.
  1. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Our friends in the UK are reporting that the production version of the 2012 Prius Plug-In will be revealed at the Frankfurt Auto Show September 15th. We're still not sure what kind of changes will be coming to the Prius Plug-In production version compared to the demonstration vehicle that we test drove last year, though I think we can safely assume that it will take on the styling changes coming with the 2012 Prius refresh that we've been hearing about. The production version will also most likely include full brake regen and user-selectable EV mode. Oh yeah... one other note of interest: UK publications are reporting that the Prius Plug-In will achieve 77% greater fuel economy than the 3rd Generation Prius, jumping from 72.4 mpg to 128.4 mpg.. That number may not translate here in the US, as the tests have been done on the European homologation blended cycle, but if it does then the Prius Plug-In could average 88.5 MPG. About 18 months ago, we reported that the Plug-In could achieve 75 MPG based on the EU ratings, so either the European test has changed or Toyota has changed something within the HSD system or battery pack to crank out the extra 13 or so MPG. Source [TheGreenCarWebsite] Extra reading - European Homologation Blended Cycle criteria (pdf link)
    10 people like this.
  2. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Can't wait to see it!
  3. StuffOnARock
    StuffOnARock Member
    98
    26
    Awesome! Something to look forward to. :D
  4. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Awesome! and September is NEXT MONTH! :)
    Any info or a link to an article/thread on the "2012 Prius refresh" that you mention above? Thanks! :)
  5. Wooski
    Wooski New Member
    241
    63
    London, UK
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    That 88.5 MPG ignores the electricity consumption. If we take account of it, the combined MPGe will be lower than 88.5.
    Remember, Volt is rated at 60 MPGe.
  7. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    Did they move the plug door? Perhaps it is on the other side since the model is RHD.
    LED projector headlights is confirmed for the PHV model then.
  8. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    Here is a cool Plugin Hybrid Synergy Drive badge.
  9. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    But, MPGe only applies to EV miles, right?
  10. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  11. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    MPGe applies to both EV and composite figures. Volt's EV is 93 MPGe. Gas is 37 MPG. Composite is 60 MPGe.
    Prius PHV's gas is likely 50 MPG. EV is probably more than even the Leaf since MG2 is less hungry and the car is lighter. Leaf's EV is rated at 99 MPGe. Prius PHV's EV should go above 100 MPGe.
    The tricky part is the composite figure. Since PHV's EV range is shorter, we don't know how many MPGe will increase from the base 50 MPG.
    For the Volt, the base 37 MPG boosted to 60 MPGe - 35 EV miles @ 93 MPGe boosted 23 MPGe.
    If the Prius PHV starts with the base 50 MPG, how much will the 14 EV miles @ >100 MPGe boost? If it boosts 10 MPGe then it would match the Volt. If the base gas MPG is 55 then it'll likely exceed the Volt.
  12. oldasdust
    oldasdust Member
    356
    47
    illinois
  13. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    I zoomed into the tire and saw the size.
    P240/50ZR16
    That's a wide tire! Wider than the 17" from Prius FIVE.
  14. Sergiospl
    3,938
    1,351
    28
    No plug-in port in this picture, this may be the regular Prius.
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That is a weird tire size! I say ditch it and go with a narrower tire and reap the MPG rewards! :p
    Seriously though, as long as they allow a blended mixed-mode EV use and allow the driver to decide when to use full EV mode then this thing will be a winner!
  16. StuffOnARock
    StuffOnARock Member
    98
    26
    Hrmm, I wonder if that's the equivalent of a Prius 5 with the LED headlights... it does have leather interior... if it weren't for the 16 inch wheels...
    Also, are those foglights integrated into the black grill in the front?
  17. Mendel Leisk
    38,648
    That tire size sounds pricey, and detrimental to mileage. Nice wheel though: maybe they will come to their senses for the whole line, regarding the wheel covers on mags?
    OTOH, that wheel/tire might not be the final product.
  18. ounlopez
    ounlopez New Member
    How come my gen 3 cannot get 70+ mpg like the ones in Europe. That is such a crock of you know what!
  19. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    EPA unadjusted combined MPG for gen3 cordless is 70.8 MPG. UK's imperical gallon is larger than US gallon also.
  20. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it is same engine, just different method of counting... UK driver gets exactly the same mpg you do.
