Programming the Smart Key
Discussion in 'Gen 3 Prius Technical Discussion' started by mhl0125, Mar 13, 2010.
  1. mhl0125
    mhl0125 New Member
    Medford, NJ
    Perhaps the answer is on here somewhere, but I haven't been able to find it. If I purchase an extra smart key for a 2010 Prius (on ebay) are there instructions anywhere on how to program this yourself or does the dealer have to do it. Thanks.
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    417
    Whereabouts Unknown
    I have the same question and will be watching for an answer.
  3. direstraits71
    direstraits71 Member
    367
    62
    Central Coast California
    This question has been asked many times for Gen 2 and Gen 3 and as far as I know, no one except the dealer can fully program a smart key. On Gen 2 you can program any keyfob to work in the ignition slot, but that's all. The keyfob has to be a new, never programmed fob for it to be fully programmable even by the dealer. By fully programmable, I mean the buttons work and the SKS wireless functions all work. As far as I know this programming requires Toyota specialized equipment and hasn't been done by anyone but a Toyota dealer.
  4. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    What dealer offers a fob at a "reasonable" price?
    What dealers consent to program an "Ebay" type fob?
    Specifically, what is the source for a "less expensive" fob that can actually be made fully functional?
    Thanks, Gary
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,053
    Northern Michigan
    The smart keys (SKS) must be programmed by the dealer, or one of a handful of commercial shops with the necessary computer tools.
    Actually, the car is programmed to the fob, not the other way around.
    Dumb fobs for the Gen II can be programmed by the user. Instructions can be found on this site.
    Tom
  6. BocaChaser
    BocaChaser New Member
    35
    Boca
    any update on this? is it possible to program one without the dealer?
  7. qbee42
    18,058
    3,053
    Northern Michigan
    Update: No, it is not possible.
    Okay, that's not entirely true. You can spend a few thousand dollars and buy a Techstream programming tool, but that isn't a good solution for most owners.
    With the Gen II Prius, you can program a smart key to work as a dumb fob, but not as a smart fob. The car must be programmed by the dealer for smart functions to work, and then only with a -new- smart key. A used smart key requires the dealer to reseed the ECU, which is a lot more expensive. The details may differ with the Gen III, but I haven't heard otherwise.
    Tom
  8. ToyotaFleetManager
    ToyotaFleetManager New Member
    160
    92
    Houston
    Gen 3 Prius SKS fobs can only be programed at a Toyota dealer. They must be new and never programed before. The ones on the internet are usually preprogramed for another Prius.
    The only other way to program a SKS fob that has already been programed on another Prius G3 is to have the dealer reflash the ECU. Basically you will have to have the dealer reflash the ECU. Which is NOT inexpensive.
  9. rrolff
    rrolff Prius Surgeon
    1,610
    244
    So Cal
    This is not correct/accurate. I had two EBay keys programmed.
    Was it easy for the dealer - no. Did it require a re-flash? No.
    Evidently, keyfobs as part of security get 'locked' after xxx uses. So an Ebay key will likely be 'locked' but Toyota dealers can 'unlock' them. This is what my dealer explained, and what they did.
    I have 4 keyfobs.
    Keyblanks can be found around $10 on Ebay - but cost $20 at most locksmiths to program (better than the $90 my dealer wanted).
  10. cproaudio
    cproaudio Speedlock Overrider
    2,399
    752
    CA
    Please provide the locksmith that programed it for you. Is it fully functional programing? remote lock, unlock, panic working? lock and unlock with door handle working? key in pocket to start working? Which dealer charge $90 to program SKS? Please let us know. I need extra key fobs.
  11. qbee42
    18,058
    3,053
    Northern Michigan
    This is a difference without distinction. Yes, technically the ECU may not need to be reflashed, but it did need to be reseeded. For all I know the reseeding process may require a reflash. Either way, the Toyota dealer has to make a phone call, prove authorization, get the new seed, flash it to the ECU, and add all of the fobs. It's not a simple task.
    Tom
  12. jayvee
    jayvee Member
    341
    86
    WA
    Actually, you can have "Techstream" for a $400 Mongoose MFC programming interface, and a $15 2-day subscription to TIS, which gives you access to the Techstream PC software (Toyota calls this "Techstream Lite").
    But you still wouldn't be able to program for the new FOB. That requires security access codes that only dealerships and approved locksmiths can obtain.
  13. RobH
    RobH Senior Member
    2,368
    970
    70
    Sunnyvale, California
    A few details...
    My understanding is that you need a $55 TIS account for 2 day access that includes Techstream.
    The $55 account allows you to add and delete keyfobs. The restricted "Security Professional" service is required to add used keyfobs or reset the ECU for all keys lost.
  14. jayvee
    jayvee Member
    341
    86
    WA
    I stand corrected on the $55. Thanks.
    Very interesting on the programming of new fobs - have you actually done this on a 2010 Prius? (The fob is different from previous years, with apparently higher security.)
  15. rrolff
    1,610
    244
    So Cal
    This I can agree with. My dealer had to make the 'call' to some place in Los Angeles, this due to 'security' - meaning each time this happens, it is not 'simple' - but far from a re-flash. In fact, they told me it was the FOB that got flashed...
  16. RobH
    RobH Senior Member
    2,368
    970
    70
    I only have experience with Gen2 SKS keyfobs. I've got the two original, two used ones, and a transponder liberated from a black logo keyfob. The keyfobs are fully functional.
    In order to register the used keyfobs, it was necessary to do a "Smart Key Reset" for each used keyfob. The process was attempt to register a used keyfob, fail at it, select "Smart Key Reset", obtain a 6 digit answer to the six digit query from Techstream, wait 15 minutes for the reset to complete, select "Key Code Registration", register all previously registered keys plus one used keyfob, repeat "Smart Key Reset", wait another 15 minutes, select "Key Code Registration", register all keys (4). I assume that a virgin keyfob would be acceptable for "Key Code Registration" without the reset. The transponder registration is separate on the Gen2, but apparently included as part of smart key registration on the Gen3.
    I've installed the transponder from a black logo keyfob into a transponder key. The transponder in a Gen1 key doesn't work in a Gen2, but transferring one from a keyfob into the Gen1 key handle does work. The key blade locks/unlocks the door, and inserting the head of the key (with the transponder) into the keyslot works just like a keyfob. There may be a transponder key that just works with the Gen2, but I haven't identified it.
    athlete11 likes this.
  17. jayvee
    jayvee Member
    341
    86
    WA
    I'd be very interested in hearing about anyone having success programming a "virgin" Gen 3 key fob themselves with Techstream Lite (and no security access).
  18. RobH
    RobH Senior Member
    2,368
    970
    70
    I'd give it about a 99% chance that you don't need the "Security Professional" status to register virgin keyfobs. Techstream only asks for the security code for the reset functions. There's the hassle of contacting Toyota for the code, plus a 15 minute delay while the reset is done. In addition to the 15 minute delay, the driver's door must be open during that period. Close the door, and you have to restart the whole process (I didn't see it, but I have a good idea how the tech found out about that one...).
    Billing a customer for the 15 minute delay while the reset takes place is a bit aggressive. Granted, the Techstream is tied up for the time, but the tech could certainly find something else to do while the computer counts its toes.
    The only improved security that I'm aware of in the Gen3 over the Gen2 is the laser cut mechanical key. And that security is based on the fact that the key pattern is cut in the middle of the key instead of the edge.
  19. syncmaster
    syncmaster Member
    229
  20. euroconic
    euroconic Junior Member
    Minsk, Belarus
    Which site?
Loading...
