Projected display of Fuel gauge , speedometer stopped working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chuba, Aug 29, 2021.
  1. Chuba
    Chuba Junior Member
    45
    Nigeria
    Good day every one.
    my prius 2012 Projected display of Fuel gauge , speedometer stopped working. That is the left side that is projected from under.
    Nothing is covering it. Is stopped working after I cleaned it with wet clothe.
    Please how do I fix it or get it working again. I drive without seeing my fuel guage speedometer and more.
    Other displays showing but the display projected from under is not work.
    Solution to get it working needed pls
    49,523
    you need to have the combo meter repaired or replaced
  3. ChapmanF
    15,702
    How wet was the cloth?
    That might be a good cautionary tale for people to remember—the part of the combo meter that works by projection means the electronics are right below that spot, if the cloth is wet enough to drip.
