Prolong Battery conditioning kit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 44Zoomer, Jul 29, 2017.
  1. 44Zoomer
    44Zoomer Junior Member
    35
    Hawaii
    I bought one and did the three discharge and charge balancing on a 2005 with 195,000 miles with no battery codes. just to condition battery. Got no change in battery condition in fact I think it got worst. Mileage went from 40 to 35
    49,500
    welcome!
    let's ask the expert, @jeff652 .
    WilDavis likes this.
  3. 44Zoomer
    35
    Hawaii
    Battery no longer holds a charge. In 3hours parked it went from 3/4 charged to 2 bars left.
  4. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    TractionBattery works much better when kept cool, I've noticed that the TB in my 2009 Gen II depletes much quicker when I have the A/C running, but I the fact that it only takes a couple of miles of driving to recover back to 65% SoC indicates that the TB isn't in bad shape (for 123,000 miles). Also I recently added the ChargeDelta (csd) X-Gauge to my ScanGauge-IIs and I've noticed it is always showing 0.0% (A Good Thing, apparently!). The regimen I use is FullRecon (3 phases) every 6 months and QuickieRecon (1 phase) every 2 or 3 months. I've had the Hybrid Systems Prolong set up for about 18 months. It's simple to use (even easier with the 5' extension cord) and @jeff652 is very helpful, and runs a tight ship, their customer support is first class! (BTW, I do not work for Hybrid Systems, neither do I have stock in that company nor have any association with them! ;))
    jeff652 and Raytheeagle like this.
  5. 44Zoomer
    35
    Hawaii
    Thank you for your reply. Great to hear from people having success with their prolong system.
  6. 44Zoomer
    35
    Hawaii
    I've read from another post that a person changed some bad battery modules and the battery still did not hold charge. He than balance the battery with a hobby charger and it fixed the problem.
    Would you think it would be a good idea to charge my battery for 40 hours to balance it?
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    You need to have some real data to look at to see what is going on.
    - Voltage for each of the 14 blocks
    - State of charge of pack data
    - Voltage for the whole pack
    Can see all this data with your android phone, the Torque Pro app ($10), and an Elm 327 OBDII Bluetooth Device ($15).
  8. 44Zoomer
    35
    Hawaii
    I order the Elm 327 obdII.
    Anyone know what is the max volts achieved on a prolong charger? I have gotten up to 237 volts around 30 hours.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    For the Gen 2 and 3 Prii it is around 240-241 volts.
  10. 44Zoomer
    35
    Hawaii
    Thanks.
    Lets hear more prolong experience. There's not that many
  11. WilDavis
    2,492
    2,153
    49
    When using the Prolong System, I've seen max of 240V, however sometimes during regular driving, I've occasionally seen 260V for a moment or two (I have one of my X-gauges set to btV (volts on TractionBattery))
  12. 44Zoomer
    35
    Hawaii
    How many hours have it taking you to get to a high voltage?
  13. 44Zoomer
    35
    Hawaii
    I'm on charger for 24 hours now at 235 volts
  14. 44Zoomer
    35
    Hawaii
    8 hours later it went up two volts. 237
    rjparker likes this.
  15. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,722
    Texas Hill Country
    I am interested in hearing how it works for you. I have read the testimonials on their site but hearing from an actual user community is always better.
  16. ericbecky
    4,371
    3,222
    Madison, Wisconsin
    Too bad none of you are part of the Insight community.
    They were on there for many years before coming here to PriusChat.
    Good folks.
    Raytheeagle likes this.
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    That's the one thing @jeff652 mentioned when he installed the harness on our 2010. Been there for many years and he has owned over 27 insights.
    The Insight community is more accepting where the Prius community is not as much :(.
    I have seen the benefits and will continue the battery conditioning process every 3 months(y).
  18. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    As a preventative measure, I liken the idea of grid charging to a gas engine and oil consumption. If you catch it towards the beginning of oil burning, you can add a quart now and then and keep the level up but if you want too long and it's nearly bone dry before adding a qt you've not helped it much for the long run. Sure that will keep it running.......for a while.
    For older cars, the sooner you start preventative care, the better.
  19. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    I'm just getting started with the Prolong system but I've been very pleased so far. I used it in June prior to our July vacation trip, a 6,500 round trip drive from coast to coast. The SOC on the MFD screen didn't fluctuate nearly as much as it was previously and the battery didn't drain as quickly as it used to on the high speed climbs with the a/c on. We drove it down to and around San Diego yesterday (262 miles total) and the car was the strongest it's been on that drive since we bought it last year. Previously were hearing and seeing lot more dependence on the gas engine to get up the hills. The battery pack no longer drops into the purple range within the first block of driving in the morning, too.
    I agree with the assessment that it is preventative maintenance. Balancing the pack won't repair a bad cell but I do believe it will keep a weak one from deteriorating as rapidly as it might otherwise.
    Raytheeagle and jerrymildred like this.
  20. 44Zoomer
    35
    Hawaii
    43 hours now and it Dropped to 235 yikes!!
