Prolong Charge/Discharge Data
Discussion in 'Gen 3 Prius Technical Discussion' started by hotelprisoner, Jan 30, 2020.
  1. hotelprisoner
    hotelprisoner Member
    101
    85
    Ontario, Canada
    Technology
    I just completed my first full reconditioning on my 2010 that was showing no signs of failure or codes.
    Unfortunately, my data collection plan failed for the first charge/discharge set but I did capture the rest.
    Notes:
    1) Capture rate was set to 1 minute.
    2) Only stabilized voltages we’re plotted.
    3) The exact procedure outlined at Hybrid Automotive was followed using the current set of discharge values (134/101/84).
    4) Total time was 5 days 18 hours.
    Enjoy.
    iPad ?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,382
    3,243
    Madison, Wisconsin
    Care to share your data collection setup?
  3. hotelprisoner
    101
    85
    Ontario, Canada
    Technology
    A GoPro set to 1 minute time lapse - I hope you weren’t thinking it was something fancy :)
    Maybe I’ll get a proper data-logger from Santa this year.
    iPhone ?
    kc410 and Raytheeagle like this.
  4. Dale2005
    Dale2005 Junior Member
    24
    25
    San Diego
    Your data graph was very helpful to me. It appears from your graph your best/last charged peaked around 243 volts. I had previously reached and stopped charging at 241 volts thinking that was as good as it will get but your experience indicated I might be able to achieve a higher top end charge if I run the charger longer.
    2GenPrius likes this.
  5. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Just purchased Prolong kit for my 2010. Can I expect an MPG increase? Dr. Prius says I have between 38-42% the few times I checked the life expectancy.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    Maybe an mpg or 2, but the battery will be more stable:).
    Never monitored with Dr. Prius, but I noticed that the battery was more stable in traffic;).
    Enjoy your new DIY equipment(y).
    Borninblue likes this.
  7. Borninblue
    233
    158
    Cleveland, Ohio
    Any tips on installing the harness? I’m assuming directions are easy to follow. I’m also thinking about cleaning the bus bars at the same time, but also trying not to electrocute myself as well. I’m adventurous DIY but usually learn by watching videos.
  8. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    Hybrid Automotive has excellent pictures to accompany the install;).
    Note that you are not touching the cells themselves, but the leads are where the harness is installed:).
    Just pull the orange safety plug and test before touch to avoid any electrical issues(y).
    sorrywereclosed and Borninblue like this.
  9. 2GenPrius
    2GenPrius Member
    188
    34
    22
    Californication
    Even though the orange plug is disconnected so you don't get the full zap from the entire pack, there is residual charge when connecting the positive lead for the harness to the far side terminal at the end of the pack. When wrenching that nut off then on, be careful not to make contact with the hybrid casing (or any ground for that matter) because you will get a quick zap as you just created a ground from the positive terminal to the case, and anything in-between.
