Promlematic/dangerous cruise control downhills?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrMagoo, Sep 1, 2013.
  1. MrMagoo
    MrMagoo Junior Member
    22
    Greetings,
    On the way back after hiking in the mountains, I've had a "scary" experience. Descending from the mountains in Norway, I had the cruise control / radar on. I, or actually my Prius, was following the car in front at aprox. 50 mph. After a while the battery was fully charged, and the car would suddenly not brake or keep the distance to the car in front. This happened quite fast, and I had to quikly step on the brake, much harder than I normally do. After braking quite hard everything was back to normal, except that the B function was not very useful, the engine just reved like crazy, not really braking anything, the car would continue to accelerate.
    The cruise control was set to just a bit over the actual speed we held, and we went way over the speed I had limited. There were no sharp turns, and the radar was always in contact with the car in front.
    Anybody else who has experienced this, or is willing to enlighten me?
    Best regards,
    Marius
  2. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Part of the issue is that the battery was full and the brakes revert to hydraulic, not regenerative....very different responses. B would also be affected. The firmware is keeping the battery from overcharging. I have a guess on the cruise control- it was using B to slow down and then lost that capability. Cruise can only slow down using the engine and it wasn't enough without the regen.
    Michael M. Maslowski likes this.
  3. hlunde
    hlunde Member
    419
    74
    To me this is a very reasonable explanation.
    What's needed is a warning message that is displayed as the full-charge condition is approached.
    Or the ABS system could be commanded to apply the hydraulic brakes, once certain conditions are met ---- full battery charge plus vehicle speed exceeding cruise-control set point or distance to other vehicle diminishing.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The speed control, whether radar assisted or not, cannot hold the car back on steep hills. Nor should you expect it to. Even with full regenerative braking plus engine braking it still isn't adequate for steep grades. Sooner or later you have to step on the brake. The owner's manual does address some of these things. There's no mechanism in the car for it to apply hydraulic braking, even if it wanted to. Please don't expect your car to drive itself.
    southernguy likes this.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I suggest that you read the owner's manual. Note the following (from the manual):
    "Note that vehicle-to-vehicle distance will close in when traveling on long downhill slopes."
    "Situations unsuitable for the dynamic radar cruise control includes: On winding roads and on steep downhills, where there are sudden changes between sharp up or down gradients...."
    Above suggests that DRCC isn't amenable for descending from the mountains, in which case you can switch to regular cruise control.
    "The dynamic radar cruise control can be set when the shift lever is in 'D'." This suggests that you don't try to use B.
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I am pretty sure that my DRCC will use hydraulic brakes. I had been cut off a few times the DRCC slammed on the brakes, way beyond the capability of the regen brakes or engine braking.
  7. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Incorrect, since either mode of speed control is equally incapable of controlling speed on a steep downhill.
  8. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    This has nothing to do with speed control, its the pre-collision avoidance system which is a separate system and unrelated.
  9. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    That may be, but at least the OP would know to slow down using regular CC as opposed to depending on DRCC working to keep the distance. I use regular CC all the time on inclines/declines with close monitoring.
  10. fuzzy1
    10,167
    How steep was the hill?
    From the perspective of someone who has never had radar cruise control, always (before Prius) had cruise controls that could not perform any downhill braking, and even with Prius find that both cruise control and B-mode braking can be insufficient to prevent runaway on some long steep hills (>7% slope), I'm having a hard time not seeing this as driver error.
  11. MrMagoo
    22
    Greetings all,
    Completely my fault, the manual is still left unopen... On the other side, Range Rover and BMW also has these functions, and they do brake. The BMW sometimes need a gentle touch on the brake, but that's all. Of course the Prius has a much smaller engine and will not hold back as much.
    Anyhows- I think it is a bit strange that a "safetybrand" like Toyota allows a car to gain speed that fast, downhill, when the passanger is laid-back, just stearing... At least it could have given me a heads up with a beep or something.
    Thanks for your inputs and information :)
    Best regards, Marius ( now braking...)
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Ah no. There was no PCS light or display. I have been cut off in similar circumstances with cruise off. The PCS did not even make a beep. I am sure the braking was done by DRCC and not PCS.
  13. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Unless it's different on the 2012-13, the 2010-11 with ATP does have a flashing PCS light reading "BRAKE."
  14. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I have seen PCS activating from the car in front of me turning right and the PCS does not know it is going to get out of my way. It does flash the light and say BRAKE!
    My point is the DRCC is capable of braking hydraulically. At 70mph, you can fill the charge bar all the way and not feel much braking force. The DRCC definitely brakes harder than that.
    My DRCC will brake, until the speed drops to 25MPH, then the cruise cancels and the car just free wheels on.
  15. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    I'll absolutely 2nd that. I've experienced our DRCC system braking many times - not in a pre-collision mode either, just a smooth even slow down as I approach a car going much slower.
