Protective panel under 2012 prius
Discussion in 'Newbie Forum' started by Carol Reynolds, May 25, 2016.
  1. Carol Reynolds
    Carol Reynolds New Member
    Montezuma Creek, UT
    I
    The tin panels under my 2012 pruis rattle when I go over rough road. Now they c are rattling while I am driving down the road. When the wind blows I hear it and am afraid it will blow off. Do I need to go to the dealer to have them secure it or could a mechanic tighten it up?
    KLD_Prius_PI_Synergy likes this.
    49,694
    welcome! anyone can do it. you have probably lost some of the fasteners, and they will need to be replaced.
  3. Carol Reynolds
    Montezuma Creek, UT
    I
    Do they have to be special fasteners?
    SAMSUNG-SM-G870A ?
  4. Carol Reynolds
    Montezuma Creek, UT
    I
    Thank you Bisco
    SAMSUNG-SM-G870A ?
  5. bisco
    49,694
    yes, you can buy them at any toyota dealer, or even some auto parts stores. i think they are just plastic pushpins with ribs.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Plastic push pins are generic.
  7. bisco
    49,694
    thank you jim.
  8. Mendel Leisk
    38,875
    It'd be best to get the right fasteners, there's a lot of variations. Unfortunately they're not cheap. Perhaps research, get the part numbers, and then search online sources. Step one though:
    Get under with some light, see what's going on, what if any fasteners are missing, what location. The fasteners vary. Whenever you have them off, wash them out with hot/soapy water. This will help float-out accumulated grit, which often causes them to fail: the mechanism jams due to grit, and they get broken during removal.
    A few tools that will help with fastener removal:
    (slim blade screwdriver)
    (paint tin lid removal tool)
    (trim removal tool)
    The panels are plastic, btw. There's multiple possibities as to why you're hearing rattles:
    1. There's a flap on the engine bay underpanel that can bent back to access the oil drain bolt location. Unfortunately it's poorly designed, subject to breaking after a few oil changes accomplished thus. It's safer to remove the entire panel, helps with inspection, but most dealerships won't do this.
    2. It's possible you've bottomed out, or run the front/back over a wheel stop or curb, or some sort of median, or road debris. Minor scrapes are inevitable, but if it's worse you may have lost a fastener or two. Inspection will help determine that.
    #8 Mendel Leisk, May 26, 2016
