PS + Main + exclamation after 12v battery swap!
Discussion in 'Generation 1 Prius Discussion' started by wwu123, Sep 12, 2009.
  1. wwu123
    wwu123 Junior Member
    62
    What a scare! I decided to change my 12v aux battery in my 2002 classic as a preventative measure, as it was the original battery going on almost 8 years. It was still showing 12.3 volts and our California winters are fairly mild. There were no apparent issues, though after 120K miles my mileage seemed to be dropping a few MPG from a few years ago. So I ordered one of those highly recommended Exide spiral batteries, and picked up the replacement kit from TSB EL014-03 that would have the larger tray and terminals that would fit, according to forum posters here. I trickle charged it for a few days to make sure it was fully charged.
    After swapping everything out and verifying 12.75 volts with the new battery, and radio and other aux functions showing normal operation, I started it up and immediately got a red triangle of death, followed by the dreaded PS + Main battery + exclamation point. Then the rough idle stalled out after about 15 seconds. Turned it off and tried again, same problem. Rechecked terminal connections and ground wire to make sure they were secure. Same problem.
    I was worried that the new battery was defective and showing low voltage under load, so I swapped back in the original battery to make sure it was the battery and not the car. Still had the triangle of death and stalling. Now I was really worried I'd blown a fuse or shorted something out in the car. Checked the small and large fuses in the red terminal connector, they seemed fine. Checked that I didn't pull loose any wires in the terminal connector, seemed like there was only a single brown one that was still secure.
    Come online to Priuschat and find other classic owners have seen this when disconnecting the aux battery, but most threads end unresolved or with some recommendations about a sticky throttle body, main battery issues, or to go to the dealer. Still convinced it's related to the disconnected battery, as my car has been running fine for years. Finally come across a few threads like this one http://priuschat.com/forums/generation-1-prius-discussion/47478-starts-then-dies.html.
    I try what worked there, putting it into neutral right away and leaving it there for a few minutes. Sure enough, the ECU or whatever fixes itself and the errors go away. I drive around for a few minutes and everything is fine again.
    Apparently this seems to be common situation if you disconnect the aux battery for too long, that the ECU gets confused during initialization or something. How terrible though that the car will actually idle rough and then stall out, even though there is nothing wrong with the aux battery or apparently anything else. Without otherwise knowing how to deal with this, the only recourse would be an expensive tow and trip to the dealer, and possibly some unnecessary repairs. Posting this just so there are more threads on trying this solution before folks end up with a multi-hundred dollar trip to the dealer...
    4 people like this.
  2. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    Thanks, we are always interested in what works. We can figure out why later! I'd guess that your car has an unusual 'fuel map' (relationship between throttle butterfly angle and fuel injector milliseconds), for whatever reason. Disconnecting the 12 would cause that relatinoship to be forgotten, so the ECU would use default values. Without much success. Any way to get the relearning started would be the right way.
    It might be wise for all to think about backup 12 volt power during battery changes, etc. if there are more important things than radio stations being forgotten
    PS: what's with the 12 guests viewing this thread - spambots?
  3. Patrick Wong
    18,200
    6,493
    Thanks for reminding us about this Classic Prius issue. When I replaced the 12V battery on my 2001 a couple of years ago there were no problems - however it did have the latest revision engine ECU installed.
    It's good to keep in mind that a problem like yours might come up (which probably is related to the engine ECU), and if so, know what to do about it. I'm wondering whether the engine ECU was ever replaced on your car?
  4. wwu123
    62
    Not that I'm aware; there was a first owner until 2004 who did have all their maintenance work and some TSB's like the "battery sealing" done at the dealer. Was there ever a TSB on the ECU that they may have done?
  5. Patrick Wong
    18,200
    6,493
    Pls note that there is a difference between an TSB and an SSC.
    TSB or Technical Service Bulletin advises the Toyota tech about a known problem, and what to do about it. Warranty coverage info is on the first page of the TSB. If your car has the problem but is not covered under warranty, then you have to pay for the repair.
    SSC or Special Service Campaign is aka a recall. The traction battery sealing is an example of an SSC, and this would be done at no charge regardless of warranty status.
    Back to your original question: a TSB was issued on the engine ECU for no-start situations. The engine ECU is located behind the glovebox. If you can get back there, check the part number label: 47054 is the part number suffix for the latest version ECU.
    If your ECU is downlevel and you want to do something about it, you could try buying a salvage ECU for around $300 or so. A new part would cost around $1K.
  6. wwu123
    62
    Thanks for the tip. I was just behind the glovebox a few weeks ago changing out the cabin air filter, so I went back to check it and the ECU is 89661-47051, probably the original one. The car has been running fine on two errands today, so I won't change out the ECU just now. I see you've helped out a lot of other folks on addressing ECU-related no-starts, so good to know in case I get a no-start in the future.
    I've found more threads where folks encounter this, no necessarily after a battery disconnect, and the stalling is generally alleviated by shifting to neutral or revving the RPM's in drive quickly. Anyone know why the ECU is suspect to this condition, and possibly might be only the older ones? It did seem that even after I got it into drive yesterday, it was still running and idling a bit rough for about 10 minutes (and wouldn't go into stealth even at stops). Then it finally "learned" enough and calmed down. Today it's running really smoothly again, and I may even have gained a few MPG's, though trips have been too short to really tell.
  7. wwu123
    62
    So just by chance this week, I had to give my co-worker a lift after a meeting as he sprained his ankle and couldn't drive. He sees my car and says "oh, you have a Prius too", as it turns out he has a 2001. He then goes on to say he's never had a problem in nearly 9 years until a week ago, when the car started with funny sounds and quit, plus a bunch of warnings on the MFD.
    He ended up towing it to the dealer, where they traced that a 12v battery cable was loose, and charged him $300 to fix the problem (not sure if they actually replaced any parts). After I described what happened to me he's sure the exact same thing happened when his cable disconnected power for too long, and that he could've avoided the whole $300 + towing cost if he'd found the trick that I did.
  8. Caroltec
    Caroltec New Member
    Upper Marlboro
    2002 Prius
    I
    After swapping out my Inverter, my 2002 Prius ran good but I noticed that my 12v battery no longer holds charge. I replaced it and behold there appeard the trinity. Are they peculiar to battery swap? Any ideas on how to resolve this problem?
  9. Patrick Wong
    18,200
    6,493
    It is probably a coincidence that the MFD warning icons appeared after the 12V battery was replaced.
    Usually one of the three warning icons will appear in a brighter color than the other two. That is the one to worry about.
  10. bwilson4web
    16,012
    No, but we need to find out if it is a hard failure or transient. I'm curious, did you swap the inverter or someone else? What was the old battery and new one? Where is the car? Did someone leave the traction battery safety lock out?
    Does the car start anyway? Sometimes you can get a transient and three attempts to start the car will suppress the error display.
    In my case, I would first read the codes to understand what the car is reporting:
    • Graham miniscanner - reads the HV, engine and battery codes. I have one out on rental and a second one available for rent ($150 deposit, $15/month.)
    • ScanGauge II - reads HV and battery codes after programming, $150-$175, depending upon source. Works best with an adapter that we can show you how to build or several of us can toss together for the cost of parts and shipping.
    • Auto Enginuity - expensive and somewhat buggy, it costs $400 plus your own laptop
    Abscent a scanner, my first step would be to disconnect the battery ground for a couple of minutes to reset all codes and reconnect. Then start the car moving the key step-by-step to see if they come back.
  11. w2co
    w2co Member
    366
    81
    Longmont, CO.
    A dirty MAF sensor also causes the triangle of death and the three boxes. All 01-03's should've had this done by now, if not that could also be the culprit. I learned this through the school of hard knox..
  12. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    I experienced a similar failure once. It turned out to be really simple.
    There was voltage drop across the terminals on the wires. I couldn't see any corrosion, but if I measured the voltage from the terminals on the battery it was healthy. I then measured the voltage from the terminal on the positive cable and on the chassis end of the negative cable. I don't remember the actual values (its been some time) but there was voltage drop.
    I lightly scraped the inside of each battery terminal with some rough sand paper, made sure they were on tight and away we went..
    Eric
  13. sbiddle
    sbiddle Junior Member
    29
    Alton, NH
    I know this is an old thread, but the same exact thing happened to me when I disconnected the neg 12V terminal to change out the steering wheel. After getting the triangle of death and a P1391 code I did some digging on the forums and found this and another similar post. By starting the car and quickly shifting to neutral and letting it idle (it wouldn't do anything else) I cleared the code and everything popped back to normal. I'm thankful someone else had the problem before me!
    Next time I need to mess with the battery (it's the original battery and so far still going strong after 10 years and 223,000 miles) I'll connect jumpers so the ECU doesn't get lost.
