PSA: Update your Wi-Fi Routers & Client OS
Discussion in 'Fred's House of Pancakes' started by Prodigyplace, Oct 16, 2017.
  1. Prodigyplace
    12,676
    11,829
    Central Virginia
  2. Prodigyplace
    12,676
    11,829
    Central Virginia
    @pilotgrrl please note. I hope your clients are patched.
    RCO and pilotgrrl like this.
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Looks like clients are the higher priority to patch, although routers can have some functionality (largely bridging modes) that will require patching. (My Mikrotik router already received a patch earlier this month, but then that's business-grade hardware.)
    The nasty thing is that a lot of routers and IoT devices are horrendously badly supported and won't get updates.
  4. Mark57
    2,945
    2,740
    OK
    Sadly, most home users don't remember how to log into their routers, much less upgrade the firmware and why.
  5. Prodigyplace
    12,676
    11,829
    Central Virginia
    They should definitely upgrade their clients though since this exploit targets the client.
  6. Prodigyplace
    12,676
    11,829
    Central Virginia
    pilotgrrl likes this.
  7. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
  8. pilotgrrl
    891
    1,797
    Chicagoan in TX
    There are lots of cheap Android devices that probably won't get patched, including mobile broadband devices that are "the only ones certified to work with" certain firewalls and enterprise routers.
    Glad I'm not at work today.
    Prodigyplace likes this.
  9. Prodigyplace
    12,676
    11,829
    Central Virginia
    Actually, I see it confirmed that both client and router/Access Point need to be patched to address this vulnerability. :(
  10. bisco
    52,386
    does this apply to comcast supplied wifi routers?
  11. Mark57
    2,945
    2,740
    OK
    It really does not matter who supplies or makes the router. It's about the security protocol WPA2-Personal & WPA2-Enterprise that the router uses as security between itself and the connecting client. If you have or use WPA2-Personal or WPA2-Enterprise then it applies. I don't know of any modern router that this would not apply to.
    RCO likes this.
  12. bisco
    52,386
    thanks, how would i find this out, and how concerned should i be, if i do have it?
  13. pilotgrrl
    891
    1,797
    Chicagoan in TX
    RCO likes this.
  14. pilotgrrl
    891
    1,797
    Chicagoan in TX
    Many devices come with default as "WPA2-PSK/WPA-PSK" (or similar) as the authentication type and encryption method.
    Patch whatever you use to connect to the WiFi router and the router itself.
    Mark57 and bisco like this.
  15. bisco
    52,386
    thanks, but i would have no idea how do go about that. i suspect 75% of home users are in the same boat.
    RCO and Mendel Leisk like this.
  16. Mendel Leisk
    41,898
    #16 Mendel Leisk, Oct 16, 2017
    RCO likes this.
  17. Mendel Leisk
    41,898
    My son's saying for home user, barring hacker neighbours and drive-by, you should be ok. Also: "If you're doing anything through an https site, like banking etc you're safe". His words, not mine, lol. And that It's coffee shop wifi and the like you'd want to be careful about, till they sort something out.
    jerrymildred, RCO and Tideland Prius like this.
  18. pilotgrrl
    891
    1,797
    Chicagoan in TX
  19. pilotgrrl
    891
    1,797
    Chicagoan in TX
    RCO likes this.
  20. Mendel Leisk
    41,898
