PSI range for Low side port
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ahartnet, Aug 27, 2014.
  1. ahartnet
    ahartnet Junior Member
    I've seen a couple of threads on this, but wasn't able to find the exact answer I am looking for, and I'm not smart enough to figure it out on my own.
    My A/C hasn't been seeming too cold lately. It works, it just takes a lot longer than I remember it last summer to get cool. I checked my low-side port using a "EZ chill" gauge I just bought. Doors open, AC max cold, recirculating and it was about 35 PSI - which I think is supposed to be about right. But I've seen it's dependent on ambient temperature - it was 90 degrees outside. According to the "EZ chilll" gauge, it suggests 45-55, which seems way to high to me based on what I've read in this forum.
    Any advice?
    Unrelated - I've only just started getting into DIY on my car. It's always been intimidating to me, but it's been a lot of fun, cost effective, and a lot easier than I would have though too!
  2. johnjamis
    johnjamis Junior Member
    79
    KY
    If you see clear fluid flowing with no bubbles in the AC sight gauge, your refrigerant level is OK. If you see a continuous flow of bubbles, you probably need more fluid.
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Original thread w/ similar question you have. Specs below and Toyota testing procedure in this LINK, are for a 2007 Prius.
    Low Pressure 35PSI = .2413MPa(Mega-Pascal) [specifications .15MPa-.25MPa]. GOOD, w/in specifications.
    High Pressure not provided by OP. [specifications = 1.37MPa-1.57MPa]. UNKNOWN if High Pressure w/in specs.
    Online PSI to MPa converter. LINK
    Good luck.
