pulling cells from a 4th gen battery
Discussion in 'Gen 3 Prius Fuel Economy' started by Darklandscape, Jun 1, 2023.
  1. Darklandscape
    Darklandscape Junior Member
    64
    I can get a hybrid battery from a 4th gen prius with 25k miles for $1000
    I was curious if everything would go well if I would just pull the cells from the 4th gen and put it in my third gen battery ?
    Btw, I am having trouble finding the oem Toyota battery online from the toyota dealerships in California, are they gone now?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    They'll work fine as long as they're NiMH. The Gen 4 NiMH module is dimensionally identical to the Gen 2 module.
    The Lithium batteries are dimensionally different and will not work in the Gen2 case.
    52,891
    they come and go like everything these days
  4. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I wouldn't bother even looking for the OEM batteries, you can get the cylindrical packs for much cheaper. Used batteries can be hit or miss... $1000 gamble, but with that low of mileage should be ok. How long have they been sitting and in what condition?
    Grit likes this.
  5. Darklandscape
    64
    Can you link me to the cylindrical pack you are referring to?
  6. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
  7. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    Ummm. there are tons of Gen 4 NiMH batteries available from low mile late model wrecks of Prius, Camry, Lexus, etc vehicles. Although most very late model ones are in the 1k range, they can be had for as low as $500-600 if you keep your eyes open. I would take a set of modules from a late model Gen 4 over a cylindrical any day of the week.
    BuckleSpring and alftoy like this.
  8. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Whichever you choose, do let us know how it went and how the MPG is after the swap. Thanks!
  9. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Gen 4 batteries G9510-47130 NIMH 2016-2022
    2020-2022 Corolla NIMH hybrid are also a good bet in salvage yards.
    RachaelH likes this.
  10. alftoy
    1,132
    520
    Cylindrical packs? Have you had personal experience with a cylindrical pack? Not sure why you are so gungho with no personal experience other than watching a ChrisFix video. I'm more inclined to take @TMR-JWAP suggestions before yours.
    Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells | Page 46 | PriusChat
    Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells | Page 47 | PriusChat
    #10 alftoy, Jun 10, 2023
  11. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    cylinder pack is the lowest quality battery that Honda used in their failed Insight. Don't ever buy D battery type NiMh that stacked like cylinder. It is old technology that has been abandoned
    Grit likes this.
  12. BiomedO1
    BiomedO1 Senior Member
    4,639
    2,434
    Left Coast
    The cylindrical traction pack on my 2006 Honda HCH failed around 70K miles. To add insult to injury, it never got the 50 mpg advertised; using every hyper-miling trick in the book. The software 'upgrade' to save the battery, made the mpgs worse. That resulted in a class action law suit.
    After the free OEM traction battery replacement; I sold it. I figure, that was the best time and the best $$$ I can get for it. YMMV
    Just my two cents....
    johnHRP and Grit like this.
  13. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    If you don't want to buy these - don't. I could care less. It's just an option, like buying an OEM battery like I suggested in another tread. I highly doubt these are the same as a $200 pack from China. Based on reviews, I highly doubt it. But if you think they are, then again, don't buy them. Buy the OEM pack, much safer option.
    Grit likes this.
  14. johnHRP
    646
    191
    KA, DE
    Excel
    Just buy original new Toyota prius battery cells and swap the electronics and get ther refund from recycling/core charge. IT is probably between $2500-$3000.
  15. rudyjoe
    rudyjoe Junior Member
    17
    Los(t) Angel(e)s
    Did you check out Toyota of Thousand Oaks? I was going to get mine from them about 2 years ago and it was about $2800 + a core charge until the old one was returned. I was going to do it since i already had experience with removing that pack but just decided on having a shop nearby do it all for $3600 since they specialize in installing only OEM toyota packs. (in the l.a. area) Not reburbed ones.
    Anyway good luck
    johnHRP likes this.
  16. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yes, this plan should work well for you with a few tips: make sure you match up the original polarity, keep the 2 blades in the same module together (they likely match capacities in the factory), and move the outside modules to the inside.
  17. johnHRP
    646
    191
    KA, DE
    Excel
    I am curious if a new battery pack for gen 3 already used gen4 cells inside.
    mjoo likes this.
  18. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Only way to tell is to take the case off and compare the serial numbers on the battery blades.
    SM-A536V ?
  19. Hayslayer
    Hayslayer Active Member
    539
    331
    Yes, they do. Even new Gen 2 packs use the latest module version.
    johnHRP likes this.
  20. johnHRP
    646
    191
    KA, DE
    Excel
    Good to hear, they are improved over the 3rd gen significantly
