Pulling the front dash window speakers
Discussion in 'Gen 3 Prius Audio and Electronics' started by aolm, Feb 29, 2012.
  1. aolm
    aolm Junior Member
    85
    New Jersey
    Anyone have photos pulling the front dash window speakers. How do the grills come out? Looks very tight to get in there.
    Tks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Follow the A/V Upgrade link in my signature.
  3. movingforward
    movingforward Member
    169
    The Great White North
    Based on Spiderman's pdf instruction, it looks like you'll have to pull the A piller covers out (I tried, it was a PITA! and only got a gap and never pursue further because I didn't want to break the tabs), then the air vent cover on the side where that small glass piece is (the side view mirrors) and then you can lift the plastic grill off the front dash.
  4. clayfree
    clayfree Junior Member
    69
    Frisco, Texas
    Pull the A pillar out until the top tab(white) pops out. You will have a gap and in the middle of the pillar you will see a black plastic tab. Take a pair of needle nose pliers and twist the tab 90 degrees and the pillar will slide off of it. It took me about 20 minutes to figure that out. From there the other panels just pull off.
    SFO and movingforward like this.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    +1 - first time was a PITA - once you know to twist the connector 90 degrees, it's simple. The grills need force to pull up/out....
  6. GreenTerrorPrius
    GreenTerrorPrius Junior Member
    56
    Good video on this subject
  7. ChapmanF
    17,355
    ... which means the people who start the job by looking in the repair manual have it too easy ... they miss out on that whole character-building first PITA experience.
    #7 ChapmanF, Oct 25, 2020
    Ed Beaty likes this.
