Pulsing WORKS!
Discussion in 'Gen 2 Prius Fuel Economy' started by Solar1953, May 23, 2010.
  1. Solar1953
    Solar1953 Junior Member
    17
    Arlington, TX
    Well, Well! Pulsing WORKS! Just tried it on a 20 mile round trip and came back with a 54+ MPG average! Great information on these forums!! Thanks everybody!:D
  2. sakai
    sakai New Member
    39
    Charleston, SC
    good work, Solar! of course, in a few weeks and a little more experience doing it, you'll be bragging about your 75+mpg drives. :D
  3. MariaEvri
    MariaEvri Member
    122
    Limassol - cyprus
    I use pulse too and gt great results. It is all ruined of course when I leave work at middays and afternoons and end up in horrific traffic!
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Yes it does! And it's a GREAT feeing to realise, I GET IT!!!
  5. Villain
    Villain New Member
    North Carolina
    I've been trying P&G for the last week (since I read about it here -- I'm a new owner of an '06).
    The biggest issues I have with P&G are that it's not really compatible with the roads I drive on, with speed limits of 50-55. In North Carolina, not driving the speed limit incites some rather serious road rage! I've tried to modify the routes I take to get to and from work in order to maximize the time I can spend on roads with speed limits less than 45 so I can take advantage of P&G, but that still only makes up about 30% of my daily drive.
    But, some P&G is still better than NO P&G :)
  6. hill
    8,158
    When I pulsed my 1st tank full into the 60's mpg range, I got an encouragement to try for the 70's mpg. Yes ... it works.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    If your speeds are only between 50-55, then you're a candidate for Super Highway Mode (SHM). See http://priuschat.com/forums/gen-ii-...angauge-best-threads-mileage-improvement.html. You'll need a ScanGauge II though...
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I don't think ScanGauge is necessary for SHM. Just use the Prius' own instantaneous MPG bar graph. Keep the accelerator pressed lightly to maintain speed and aim for the highest achievable instantaneous MPG below 100 MPG. It's easy to tell when one gets out of the SHM: If the accelerator is pressed harder, one will see a quantum jump to lower MPG. If the accelerator is pressed not hard enough, there will be a quantum jump to 100 MPG. Good luck!
  9. dabize
    dabize New Member
    98
    Sudbury, MA
    In my record of my 28k miles on my 09 (I drive a lot) it says under "cumulative" for February 14th 361.66/19,161 (53.0 mpg)
    Then it says "started P&G"
    This week it said under "cumulative since P&G":136.84/7825 (57.2 mpg).
    I am currently getting over 70 MPG on the dash, and my last 2 tanks were 69.2 and 68.1 MPG.
    I'll say it works.....
  10. hill
    8,158
    OCD ... yes, you've got it bad my friend ... this may call for intervention. The first step to recovery is admitting it. You can admit it. Do you feel great discomfort when you fall below 60mpg? Welcome to my world.
    :p
  11. dabize
    dabize New Member
    98
    Sudbury, MA
    I think that most folks here have it as bad as I do.....at least as bad. For example, I have no Scangauge.....
    Gotta say, though, that one of my students saw my record file up on the computer and was kidding me about it (good humored kidding - she said she's probably do the same if she had a Prius).
    It felt a bit as if I had been caught with porn, though........
