pump over filled tank by gallons and now guage not working
Discussion in 'Gen 2 Prius Main Forum' started by JimPriusPoe, Sep 23, 2011.
  1. JimPriusPoe
    JimPriusPoe New Member
    san jose ca
    I set the auto fill at the chevron pump to fill the tank.
    the autofill never shut off and fuel sprayed everywhere.
    fuel leaked out for 15 minutes from the fill port
    I had the pump checked by weights and measures and the pump is not at fault
    Now the fuel guage is stuck at full
    Help
    any suggestions ?
  2. Comrad_Durandal
    Comrad_Durandal New Member
    170
    Minneapolis, MN USA
    Besides get it checked by a Toyota dealer, or an ASE certified mechanic?
    51,155
    how many miles have you driven since filling?
  4. djras
    djras New Member
    32
    Victorville, CA
    I typically get almost 100 miles before my gauge goes off of full.
    Also, there IS clearly something wrong with the pump. It SHOULD have stopped before it poured 3 gallons in the ground (and everywhere else).
  5. JimPriusPoe
    san jose ca
    pumped 12.197 gallons of which I would say 3 gallons sprayed back on me and the ground
    tank was 3 bars full prior to filling
    have driven 200 miles and fuel guage still reads full
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    give it another 50 miles, that full it may just not have reached the limit yet...that said, I'm worried about damage too.
  7. bisco
    51,155
    if it's running fine, you're fortunate and perhaps it will somehow reset itself in a few tanks. no harm in having a dealer look at it, but i would give it some time before i paid anyone to repair it.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    You haven't driven far enough to burn off the excess fuel. Once you do, the gauge will start moving again.
    Tom
  9. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I've seen 100+ miles (sometimes pushing 130) before the first pip goes away. Your tank is more full which means that you might see 150+.
    I wouldn't be overly concerned if it were my car. I'd just make sure I washed it well to get all the gasoline off the paint.
  10. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I've had this happen to me too. The tank was very full and it took nearly 200 miles before the first pip dropped. I wouldn't panic on this quiet yet. Dive another 200 miles and the pips will start a droppin.
    Other people here have reported similar problems after overfills but they always eventually worked themselves out and were back to normal after a few tankfuls.
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    BTW I forgot to mention why it happened to me. In a nutshell it's caused by pumping too slowly.
    The more slowly you pump then the less back-pressure is produced and the more likely it is to fail to trip the cutoff. In the case when it happened to me the slow pumping was the fault of the pump, due to an almost fully blocked filter, but you can get the same effect from just manually controlling the pump lever to make it slow.
  12. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    state board of weights and measures wouldn't cover this, I don't think. They would just cover if it was measuring a gallon corrcectly not whether there was some sort of failure of the auto-off feature.
  13. richard schumacher
    7,664
    1,043
    United States
    That's one reason why you should always stay at the pump with your hand on the nozzle. Here's another:
    [ame=http://www.youtube.com/watch?v=b3x-8tj49ac]Gas Pump Fire - YouTube[/ame]
  14. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    In Victoria and I think most other Australian states the trigger locks have all been removed by regulation and new pumps don't have them.
  15. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah in Australia when petrol stations went to "self serve" then by law they had to remove the trigger locks. So you don't have any choice but to stay there and hold the lever while filling.
  16. Stormz
    Stormz Member
    105
    Perth, Australia
    Our Prii have the proper metal tank though as well, not the bladder thing, which is probably more susceptible to problems.
  17. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    A few years back before the trigger locks were removed, a guy on the cell phone mistook my car as his (wasn't even the same color or type of car) and pulled the nozzle out spraying fuel everywhere. I have learned to "guard" my nozzle ever since.
  18. bisco
    51,155
    they have removed them in mass too.
  19. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Now that's one I haven't heard before. About the only way that could have been worse is if there was a cigarette involved.
    FWIW, we still have trigger locks here. Some stations took them out years ago but then put them back when they went to digital pumps with card readers. I think some stores still don't have them but I can never remember which do or don't so I just look and adjust my habits based on the store having them or not.
    Oh, really that was how I thought of it before I got the Prius, now I add that to the mix. I still put gas in a plastic container for the lawn tools, the 2nd car, etc. I don't like using the trigger lock with the Prius but if I do I keep my hand on the outside handle ready to release it when I hit a few gallons from full so I can slow it down and see how much will go in at a slower speed.
